04-16-2015, 11:50 AM | #1 |
Brake line size?
Hey guys getting ready to plumb my brakes and need to choose a line size. Brakes are 6 piston front 4 piston rear with a 1" wilwood manual master cylinder. Thanks
04-16-2015, 02:18 PM | #2 |
Re: Brake line size?
I used 1/4 inch front and rear. Number of pistons doesn't change line size but does affect the amount of fluid you need to add as the pads wear.
04-16-2015, 06:00 PM | #3 |
I use 3/16". One each for front disks and one shared for rear drums.
04-16-2015, 06:14 PM | #4 |
For a 6 piston caliper disk, recommend ask the mfgr. Factory used 1/4 all the way around for drums pre-71, and then 3/16(front) and 1/4 rear for 71+ disk/drum pkgs. If there's not a mfgr recommendation, I'd go with 3/16" all the way around for a 4-wheel disk setup.
