Old 04-16-2015, 07:35 PM   #1
A1971Blazer
A1971Blazer's Avatar
Oil pressure port....?
I'm gonna run these gauges....got a few hundred off from a member....this will save me some time..........thanks again man...!
fairly good match to factory gauge scheme......
I got this GM "hot rod swap" oil pan..........
and this is the F-body pan............sorry...it's cracked
this looks to me, like a drill and tap place for the oil PSI sender....?
I can drill and tap either one if that location has full oil pressure.....but the F-body one is almost there......I suppose it will be an issue of clearance....
A1971Blazer is offline   Reply With Quote
Old 04-16-2015, 09:29 PM   #2
dec010974
dec010974's Avatar
Re: Oil pressure port....?
Hello a1971blazer. Both of those oil port caps are interchangeable with LSX OIL pans. Both of the oil port caps can be tapped and threaded to read oil pressure from the oil pressure unit. It may easier to use the oil pressure port/sending unit in the back of the block, located by the camshaft sensor
dec010974 is offline   Reply With Quote
Old 04-16-2015, 09:51 PM   #3
A1971Blazer
thanks man........from what I have searched up, the ECM uses only a low oil pressure signal to turn on a warning light....so that would be easier......I won't have a light.
Old 04-16-2015, 11:01 PM   #4
H20cooled
The ECM does not have an oil pressure sensor so you can use the rear port with no issues. That is what I did with my Dakota Digital gauges works great.
H20cooled is offline   Reply With Quote
Old 04-17-2015, 06:53 AM   #5
A1971Blazer
10-4........thanks....that's what I'll do......does it need a special adapter?
Old 04-17-2015, 08:45 AM   #6
H20cooled
Originally Posted by A1971Blazer View Post
10-4........thanks....that' what I'll do......does it need a special adapter?
you shouldn't but that will depend on your gauges, the threads are metric. My gauges came with a bunch of different sized adapters so it made it really easy. I would install the sensor before you install the motor, its not easy to reach that area back there when its installed.
Rich
Old 04-17-2015, 09:01 AM   #7
A1971Blazer
I'll check the package for any adapters.......and it should be easy to reach right now........
Name:  photo 1 (1).jpg
Old 04-17-2015, 09:10 AM   #8
uxdesigner
I'm also considering these exact gauges and interested on how you setup the oil and speedometer. Wondering if the speedometer is a simple plug and play, single wire VSS? Please post pics as you go, good luck!
uxdesigner is offline   Reply With Quote
Old 04-17-2015, 09:25 AM   #9
A1971Blazer
Will do......but I'm a long way from there......
I glanced through the instructions briefly when I got the gauge assembly. It will work fine with the VSS but it requires their signal converter.
I assume that would be to used calibrate the speedometer with different tire sizes, gears etc.....? Luckily I got that with the kit too.....
Signal Converter
Old 04-18-2015, 11:38 AM   #10
mattcrp1
mattcrp1's Avatar
autometer makes an adapter for the oil pressure switch to NPT. I went with this adapter for my 76 (I have not put it in yet).
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-19-2015, 12:48 AM   #11
crazy longhorn
Fabricate till you "puke"
Same deal on mine....I have installed it, & it worked out just fine Metric thread in the block, sealed with a copper ring,to npt on top....fittings pretty much with any guage set will work after the adaptor. The part was 10 or 12 bucks ....Summit, Jegs, or Car shop inc.... Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-19-2015, 01:00 AM   #12
mattcrp1
mattcrp1's Avatar
Hey Longhorn, what size is the base of the stock LS oil switch? i can see it but cant get a wrench on it.
I liked this location better than down lower by the exhaust. That's why I went this direction.
IG mattcrp1
Old 04-19-2015, 01:24 AM   #13
crazy longhorn
Man, its been a couple yrs since the swap....I will try to dig up the stock switch, & get a size for you, if nobody else has it :right of top'
...longhorn
Old 04-19-2015, 07:20 AM   #14
dec010974
dec010974's Avatar
hello mattcrp1. the thread size is m16 x 1.5. Auto meter sell an adapter for those who want to run the autometer electric oil pressure guage. Autometer #2268 is the adapter's part number.
Old 04-19-2015, 09:11 AM   #15
dayj1
It's 1-1/16". Part of the problem is that the corners of the hex on the sender are rounded which makes a lot of wrenches/sockets slip and not "bite" the sender. Most of the big box part stores carry an oil pressure sender socket specifically for the job. Here's a pic I snagged off the web showing the socket opening.
dayj1 is offline   Reply With Quote
Old 04-19-2015, 11:15 AM   #16
First c10
First c10's Avatar
This is what I had to do for my sons c10 with a gen IV motor as the ecm needs to read oil pressure. I can attach a picture installed.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-19-2015, 02:29 PM   #17
mattcrp1
mattcrp1's Avatar
Thanks guys.
Matt
IG mattcrp1
Old 04-25-2015, 12:35 AM   #18
mattcrp1
mattcrp1's Avatar
I used a 1&1/16 crow foot socket and removed the stock ls switch. plumbed up the new one and cranked it over works fine. thanks for posting this.
IG mattcrp1
