Old 04-16-2015, 10:43 PM   #1
kingsolver72
10/30/19
kingsolver72's Avatar
Transmission question
I am thinking about purchasing a 400 turbo trams for my 72 c-30. The truck has a manual 4 speed now. My question is, other than installing an automatic column would I need to shorten or Lengthen the the drive shaft? I'm pretty sure I won't be able to use the crossmember.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 04-16-2015, 10:57 PM   #2
tranz am
tranz am's Avatar
Re: Transmission question
You can use your crosmember just slide it wher you need it and drill new holes.
as far as driveshaft you will need a th400 yoke you will need to shorten the driveline or move the motor and trans forward.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-16-2015, 10:59 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
You have to check the yoke coming out of the trans. I don't know on the 4spd, but the TH400 yoke is bigger than everything else I have worked with. You will have to measure the trans to see what to do with the shaft. Most swaps I have done I had to shorten the shafts. Don't forget about a trans cooler.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-17-2015, 12:20 AM   #4
wbc409
The TH400 also requires a kick down switch and associated wiring. It is NOT vacuum controlled like a glide or TH350
wbc409 is offline   Reply With Quote
Old 04-17-2015, 12:30 AM   #5
SS Tim
SS Tim's Avatar
If it is a C30 4-speed truck, you will need to remove the crossmember at the bellhousing along with the rear engine mounts.
Because the factory 4 speed is a cantilever installation you will need to source a factory C20-30 automatic crossmember with braces, transmission mount and the frame spacers as well. This will convert it from four mounts to three.
SS Tim is offline   Reply With Quote
Old 04-17-2015, 05:15 AM   #6
kingsolver72
10/30/19
Thanks for all the help! Hey SS Tim I'm not sure about the term 'cantilever installation'? I need to replace the engine and thought a 400 trans would bring the rpms down. Sounds like there is a little more involved than I want to do for now. When I do the engine swap would it be easier to pull it with the trans or leave the trans in?
Old 04-17-2015, 01:21 PM   #7
frankslagoon
ya know the high gear is the same in the 4 speed as the turbo 400 1:1
frankslagoon is offline   Reply With Quote
Old 04-17-2015, 01:39 PM   #8
SS Tim
SS Tim's Avatar
Sorry, Ok, the the engine sits on four mounts (four points), two front side mounts and two rear supporting the bellhousing. Kind of sits there as a power egg. The transmission is stabbed into the bellhousing and bolted to it alone. Meaning it just sticks out in space there without a transmission mount or rear crossmember. That is what makes it a cantilever installation.
On the automatic the rear engine mounts are not present and a singe transmission mount is used at the rear to support the trans and the engine as an assembly. That makes it a three point support.
Either the current four speed or a TH400 are a direct or 1:1 final drive. Meaning the input and output RPM are considered the same.
So changing the trans wil not reduce the engine RPM for a given road speed at all and given torque converter slippage will actually be a little higher.
To lower the engine speed the choices are limited to,
taller tires (limited change)
overdrive transmission, like a NV4500 0.73:1
add on overdrive, like a gear vendors 0.78:1 (expensive but allows splitting lower gears too.)
re-gear rear, with the choices of 4.11, 4.57 and 5.13 for a HO72 there isn't much to be gained there either.
http://www.summitracing.com/expertad...tio-calculator
Old 04-17-2015, 05:41 PM   #9
kingsolver72
10/30/19
Lots of good info. I thought about taller tires, won't that change the speedometer reading? Is it hard on the engine if I drive 70 mph on the highway? Don't like driving 55 on the interstate,
Old 04-17-2015, 06:32 PM   #10
SS Tim
SS Tim's Avatar
Thanks!
Yes the speedo will be slow and the odometer will indicate short with taller tires because the taller tire rotates slower for a given road speed.
I'd suggest playing with the calculator I linked to above so you can see the effect on engine RPM by changing tire size or differential gearing.
As to what your engine is doing at 70 MPH... I don't know.
But as examples, with 30" tires a 4.57 differential and 1:1 trans ratio the engine would be turning about 3583 RPM @70 MPH.
Stepping up to 33" tires results in 3257 RPM
If we went 30" tires and 4.11 gears it drops to 3222 RPM
Or 33" tires and a 4.11 gears would give 2929 RPM
As I said above the actual change is limited with the gears and to an extent tires.
Old 04-17-2015, 07:58 PM   #11
tranz am
tranz am's Avatar
if you want to drop rpms at cruise speed look into the 4l80e or 700r4/4l60.
My build thread
1969 GMC SWB
Old 04-17-2015, 10:20 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have a '70 Chevy 3/4 ton truck with 400 engine/400 trans and 3.55 rear gears. I have yet to hook up the tach since I went to HEI, but that will be happening soon. Feel free to PM me if I don't give you an answer real soon. I'm working some home remodels/repairs for the foreseeable future, so don't have a lot of time to work on the truck.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-18-2015, 09:24 AM   #13
What ratio do you have now? If not 4.10, grab a center section and plunk it in. Taller tires would be worth it. What do you have, 235/85-16s? I'm not sure you can run 255/85s w/o extra spacing/studs but if they fit that would be a nice improvement.
Old 04-18-2015, 01:38 PM   #14
kingsolver72
10/30/19
Yes tires 235/85/16. Not sure about the gears. Been raining here in Ks. and my shop is too full to pull the truck in out of the rain.
On a different note, I was looking at the spid and noticed "Dr Wheel Conversion".
Anyone know what that means?
Thanks again for all the replies,they've been very helpful!
Old 04-18-2015, 01:49 PM   #15
SS Tim
SS Tim's Avatar
RPO "RO5" is the conversion of the base truck to DRW (dual rear wheels) by the factory during assembly. Basically a different rear axle/brake assembly and front drums or rotors with a spacer to allow the ~6" negative offset budd wheel (same as one of the rears) to run correctly.
