Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-17-2015, 12:44 AM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
1966 GMC Suburban front disc brake conversion
I am converting to front disc brakes and have some questions. Removed closed knuckle Dana 44 and installed a Dana 44 with discs from a 1985 4x4 blazer. My sub is 4x4 as well. Is the power booster I have original to my sub? From what I have read I will need a new master cylinder for disc/ drum. Then I will need a pro portioning valve and new brake lines and then get a push rod from booster to master. I may need a new push rod from brake pedal to booster as the brake pedal is really close to the floor. Am I on the right track?
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 04-18-2015, 01:58 AM   #2
Captainfab
60-66 Nut
Re: 1966 GMC Suburban front disc brake conversion
Yes that booster is original to your Suburban. And yes you will need a disc/drum master cylinder and a prop valve. That booster has the long intermediate pushrod which makes finding the correct master cylinder a little difficult. The first one that comes to mind is the '67-'76 Corvette master. Even though those are designed for a disc/disc application, many use them with a disc/drum system. The Corvette master cylinder is basically what most aftermarket boosters are that are sold for these trucks.
The alternative would be to replace the long intermediate pushrod with a short one and then you have more choices for a master cylinder.
Old 04-18-2015, 04:03 PM   #3
Baketown Scotty
Junior Member
Thank you Captain. I'll get the search going. There is a plate between booster and firewall that makes the master point over to the drivers side. This could make plumbing in the prop valve snug to the inner fender. Thanks again.
Old 04-19-2015, 07:10 PM   #4
Baketown Scotty
Junior Member
I checked Carquest and Autozone and they both have the Corvette master cylinder with 1-1/8" bore. The old master cylinder is 1-1/2". Will that be a problem?
Old 04-26-2015, 09:55 PM   #5
1966burb
1966burb's Avatar
Just finished up the disc brake swap on my 1966 Burb that had factory power drum brakes. Push rod length was ok. I checked the hole depth on old master cylinder compared to new one. Proportioning valve bracket had to be shortened and "tweaked" a little. I had to remake both short lines from master cylinder to proportioning valve. I plan to hide to proportioning valve down in the frame someday when I pull the engine out. I used a ECE disc brake kit.
1966burb is offline   Reply With Quote
Old 04-29-2015, 04:14 PM   #6
Baketown Scotty
Junior Member
Just ordered a master cylinder from Autozone (new $27) and the proportioning valve from ECE. ECE said I would be getting a brass one like 1966Burb's picture, not the cast iron one from Delco shown on line. Now need to get a double flare tool and get it all installed. Thanks all.
Old 05-01-2015, 12:11 AM   #7
Baketown Scotty
Junior Member
Since the master cylinder I am buying was originally for a disc/ disc setup, will the front outlet of master cylinder go to front brakes and rear port to rear brakes? Or is it reversed as I have read on some other threads? The master cylinder I am buying from Autozone is part number NM1372.
