Old 04-17-2015, 04:10 AM   #1
Siedl
Question Incomplete HEI conversion...what to do
Hi! I just picked up a 72 gmc stepside and from what I can tell they attempted to convert to an HEI ignition but didn't change the distributor, left the vacuum hose detached from the carb and hanging, unplugged and didn't change any of the spark plug wires.
The truck has started randomly dying, today going 40mph. My research tells me it could be timing or carburetor but wonder if it could be the unfinished conversion/possibly the vacuum hose that's just dangling there.
Any guidance is appreciated! Thanks in advance!
Siedl is offline   Reply With Quote
Old 04-17-2015, 07:23 AM   #2
hugger6933
Re: Incomplete HEI conversion...what to do
Welcome to the site, you need a HEI dist of course with cap and wires then you need a hot with IGN on a 12 volt source most run a wire from the fuse box. Then you need to plug up that vac hose that is just hanging out off of the vac source. Set the timing and then your pretty much ready to roll.
hugger6933 is offline   Reply With Quote
Old 04-17-2015, 02:32 PM   #3
Siedl
Question Re: Incomplete HEI conversion...what to do
Thanks so much for the step by step! Do you think this could be why the truck is randomly dying? I've had people tell me everything from carburetor to fuel pump to timing. Was going to try a new fuel pump first since it's the easiest but don't think that's really the issue...
Also, should I plug the carburetor where the vacuum hose went or just plug the hose coming off the distributor? Sounds likes silly question but I'm still getting through the learning curve!
Thanks so much! My mechanic partner bailed and left me without his expertise so this forum has been a great support!
Old 04-17-2015, 03:28 PM   #4
68350
68350's Avatar
The carb side is the vacuum you need to plug. But if the distributor is set up for vacuum advance you should hook the hose up
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 04-17-2015, 03:30 PM   #5
COBob'70 K-10
Just a suggestion:
While you can run the hot wire to the fuse panel, I ran mine to a toggle switch. Now, no matter how long the engine is cranked, until the switch is on, no ignition.
Call it a cheap bit of security.
COBob'70 K-10 is offline   Reply With Quote
Old 04-17-2015, 03:44 PM   #6
Davidf
I wanted to free up the "ignition on" spade terminal in my fuse box, so I order a new engine wiring harness for HEI from Classic Parts. All the conversion wiring is integrated into the new harness and looks totally factory. Well worth the $100 or so. Plus it was an easy way to clean up all the hacked up existing engine wiring. If you go this route, don't forget to order a new wiring junction block gasket.
Davidf is offline   Reply With Quote
Old 04-18-2015, 01:42 PM   #7
Siedl
Smile Re: Incomplete HEI conversion...what to do
Thank you guys so much for your replies. I'll let you know how it goes.
Old 04-19-2015, 06:43 AM   #8
dirtyjim
dirtyjim's Avatar
m&h sells the hei lead for around $6 with the hei terminal on one end and Packard 56 terminal on the other. cant build one for that price. they are also sold through oc truck shop.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 04-19-2015, 10:58 AM   #9
leftybass209
leftybass209's Avatar
Definitely can't build it for that! I know because I did. I don't like splicing so I have an HEI harness from m&h, and a modified alternator/headlight harness so everything looks factory, no extra wires, and no chance of a short due to negligent splicing.
Sorry I got off track. I would start by looking at a schematic here for HEI. Take your time, trace your wires, and make sure it's all correct. Then of course, by an HEI distributor!
leftybass209 is offline   Reply With Quote
Old 04-21-2015, 02:51 PM   #10
michael bustamante
michael bustamante's Avatar
quick question though. if you have a good oem harness and its still very useable, what can you do with the two yellow wires that used to be on the oem coil? maybe for the electric choke?
1967custom
michael bustamante is offline   Reply With Quote
Old 04-21-2015, 03:11 PM   #11
bronze 72 super
bronze 72 super's Avatar
Yes, as long as the power source is off when the ignition is turned off, and key off. Did this on my '70 El Camino with a holley with electric chock. No problems.
bronze 72 super is offline   Reply With Quote
Old 04-21-2015, 10:26 PM   #12
michael bustamante
Cool thank you
1967custom
