04-17-2015, 09:42 AM | #1 |
Radiator help please.
Just picked up a 1971 k5 ...... radiator seems fine but it does not look long for this world. Fins are punkey....
Where is the best place to get a radiator???
1970 chevelle 1971 blazer 1972 c20 custom camper 1931 ford A coupe. |
04-17-2015, 09:53 AM | #2 |
2WD Jimmy
Re: Radiator help please.
Why not reseal and recore?
04-17-2015, 09:54 AM | #3 |
just thinking turn around time... truck is running and driving now.
04-17-2015, 10:43 AM | #4 |
RADIATOR Help please
04-17-2015, 10:57 AM | #5 |
You trying to stay stock or go modern?
Be Cool has a good reputation for radiators. Check out your water pump as well and make sure it's pushing enough volume through. |
04-17-2015, 11:08 AM | #6 | |
Stock would be fine... Its a driver. but doesn't really matter. Like I said... seems like its fine, Just has some green fins. Dont want to trust it.
04-17-2015, 11:25 AM | #7 |
depending on what you have stock 4 cores have gone up. bought one 5 years ago for $ 215 now $350. is cheapest I could find.
04-17-2015, 11:26 AM | #8 |
04-17-2015, 11:47 AM | #9 |
Re: RADIATOR Help please
Myself, and several others have had great success with Champion radiators. They come in 2 row, 2 row with 1 inch tubes, 3 and 4 row. They're sold on ebay all the time.
04-17-2015, 12:09 PM | #10 |
i want to work with the factory shroud and top mounts.... Did yours?
04-17-2015, 01:14 PM | #11 |
All about them K’s
I need one too. I want a 4 core but on eBay I can only find 2 and 3 cores... Maybe I'm doing something wrong.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-17-2015, 03:43 PM | #12 |
The older 3 and 4 core radiators have small cooling cores.
Newer 2-row radiators like ours have 1-1.25" thick cores for more efficiency, and a lifetime warranty! http://www.speedcooling.com/1967-197...r/prod_38.html or our premium setups: http://www.entropyrad.com/radiators/...evy-truck.html
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
04-17-2015, 03:55 PM | #13 | |
Im just thinking for a bolt in replacement i dint want to have to fab anything on this truck... want all the hold downs and rubbers to work. ya know.
04-17-2015, 04:00 PM | #14 |
Totally understand!..our stuff is designed to bolt right in, using the 4-row lower mounts and factory hold downs
04-17-2015, 04:09 PM | #15 |
All about them K’s
Do you offer a forum discount by chance?
04-17-2015, 04:12 PM | #16 |
PM Matt at MCB..he's a dealer for us, and will get you pricing!
04-17-2015, 04:16 PM | #17 |
All about them K’s
Thankyou sir!
04-17-2015, 05:49 PM | #18 |
Shawno has pics of his champion radiator installed here, it's post #75 http://67-72chevytrucks.com/vboard/s...=663051&page=3. He got the standard 2 row and said it doesn't overheat. I have a champion 3 row that doesn't overheat at idle without a shroud, but I just purchased their 2 row with 1 inch rows so I can use my shroud. ( I purchased the wrong size 3 row) they bolt in, look great, carry a warranty, and can be had on ebay cheap. I can't speak to the quality of the entropy radiators, not too many people have posted about them yet. Best of luck with either, but if you go with entropy, post some pics of real world fit and function!
04-17-2015, 07:36 PM | #19 |
Can anybody tell me what I have?
04-17-2015, 07:39 PM | #20 |
04-17-2015, 07:57 PM | #21 |
It looks like you have the shorter 2 or 3 row mounts. Look into the radiator cap hole towards the core ( you might need a flashlight) you should see some thin side by side slits. If you see just two of them l--l it's a two row. If you see three of them l---l it's a three row. Those will be stacked all the way up the core height.
04-17-2015, 08:03 PM | #22 |
I run a 2 row champion myself. Only problem I had was with the threads for the tranny lines stripped out when installing them. So I bought a heavy duty trans cooler and mounted it in front of the radiator.
04-17-2015, 09:54 PM | #23 |
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
04-18-2015, 02:28 AM | #24 |
local autoparts store has em
04-18-2015, 06:02 AM | #25 |
