04-17-2015, 11:49 AM | #1 |
Wish me luck
Did my physical last Saturday.
Got my Chassis cert on Wed. Everything is done on the truck except Longer wheel studs in front and replacing my belt as it is out of date. Doing both today. If all goes well, I hope to make my license passes this sat.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-17-2015, 12:02 PM | #2 |
Re: Wish me luck
Good luck. I wanna see that thing run!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-17-2015, 01:24 PM | #3 |
Re: Wish me luck
Goodluck! Im sure you will be perfectly fine.
04-17-2015, 01:43 PM | #4 |
Re: Wish me luck
Good Luck,hope everything goes well
04-17-2015, 01:45 PM | #5 |
meowMEOWmeowMEOW
Re: Wish me luck
Good luck! Mind telling us about the physical?
I've always wondered if I'd be allowed to get my license because of that part.
04-17-2015, 07:34 PM | #6 |
Re: Wish me luck
Good luck hope everything goes your way.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 |
04-17-2015, 08:18 PM | #7 |
Re: Wish me luck
Good luck!
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
04-18-2015, 04:43 AM | #8 |
mini truck racer
Re: Wish me luck
Good luck and have fun .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-18-2015, 09:38 AM | #9 |
Registered Truck Offender
Re: Wish me luck
The licensing passes are so stupid,, I've never understood the 60',,1/2 track,,then full pass.. annnd good! It SHOULD BE 1/2 track, full pass, then go see how thy handle the shut down!!! Things are more exciting on the top end than in that first 1/2!!! Oh well that's why I'm not running NHRA I guess (common sense!)
BR3, the physical is really just standard stuff (BP, blood sugar, history is seizures, bla bla) but the did throw a couple of things in there because guys are notorious for not taking care of themselves (prostate exam 'if warranted', EKG if over 50, to name a few) The medical form is on-line if your a NHRA member, if not let me know I'll i have it saved somewhere. Shaun, we'll be watching to know how she does on that 3rd hit!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
04-19-2015, 11:00 PM | #10 |
Re: Wish me luck
1 pass and bsck on the trailer. Electric fan came loose and ate the radiator. Next month I guess.
04-19-2015, 11:23 PM | #11 |
Re: Wish me luck
Well that sucks.
04-20-2015, 08:40 AM | #12 |
Re: Wish me luck
Man come on Shaun,, don't YOU start a string of bad luck with STUPID stuff like I had!!!
How the HELL does an electric fan get loose???
04-20-2015, 11:18 AM | #13 |
Re: Wish me luck
Marv,
As I was unloading all my gear back in to the garage yesterday I could not help to wonder if some how I am ending up with your luck. Let's hope not. I have a new radiator and fan set up on order.
04-20-2015, 08:39 PM | #14 |
Re: Wish me luck
Man U can't win!!!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-21-2015, 08:25 PM | #15 |
Right on the line, baby!
Re: Wish me luck
Hey, it's only a month. Don't let it get you down. Looking forward to hearing about it-
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
05-04-2015, 07:10 PM | #16 |
Re: Wish me luck
Ok.. Quick update:
Ordered new radiator, fan, shroud. Put it all together and dropped it off at my buddies to weld the mounting tabs on. While waiting I decided to figure out a starting issue I was having. Turns out when installing the new throttle position sensor, I forget to set the min voltage on it to >0.2v and it was throwing a code, causing a hard to start issue. Fixed it, fired right up but then there was a noise.... It sounded like a rod knock or collapsed lifter. I cant see how it would suddenly develop a rod knock when it didn't have one leaving the track so I pulled the valve covers, rolled the motor over putting each set of lifters on the base of the cam looking or a loose push rod. Nothing.. Pulled the oil filter and cut it open, nothing to be concerned about in it. As I got under it and started draining the oil, I noticed one of the cut outs was not closed all the way and tapped it. It make a clacking sound. Thinking I found it, I filled it back up with oil, started bolting down the rockers and well... Wouldn't you know the last bolt spun in the head... Grrrrr... Off came the intake, drilled, tapped the hole and put a heli-coil in it. Since the plugs were out, I turned it over with the key and no noise. Put plugs in it and left the coil pack unplugged, turned it over and the noise was back. Pulled the even plugs out trying to narrow down what side it was coming from. Still there. One by one I pulled plugs and the noise lessened. Got to number 7 with the noise still there and moved that plug to number 3, still had the noise. Got back under to inspect the flexplate for a crack and could not see one. I unbolted the converter, slid it back and reached up and the flexplate bolts backed off Unbolted the trans, pushed it back, pulled all the bolts out cleaning the holes and bolts and put them back in very tight with loctite. Got it buttoned up and the noise was gone. Took it for a test ride when I had a rotational vibration. I must have tossed the weight off the front drivers tire, got that taken care of. Got the tune more or less back in order other than it is under timed by roughly 6*. It feels strong and the tires have zero chance from a 25mph roll even with the front shocks at the 6th loosest setting. It transfers the weight while unloading the tires. Back testing it at the track on Sat/9.. I think I will play with it this weekend and work on my license in June.
05-05-2015, 07:56 AM | #17 |
Re: Wish me luck
Dangit I'm worn out after reading all that. Sounds like you got it figured out. Good luck at the track.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
