Location: Fredericksburg Texas formerly Ranch Road 1...LBJ's Road...
Suspension swap for Logan's 66 question
I know with time searching, I can find what I need but I want to get fresh info. Logan sold his 283 (has LT1 now) so he has $450 to put in his suspension. My though is to try and find a later model donor truck. He has a spun bearing in the rear diff and drum brakes all the way around. 5 lug all the way around with disc's up front and maybe discs in the rear later. Chassis is ready to go, painted by Logan...
I want everyone's input on the best way to go for the money... Thanks, Paul... ![]() ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Suspension swap for Logan's 66 question
drop?
I would find you a donor, hopefully cheap. I would send Logan to talk to the guy if its an individual, just for the kid factor!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Feb 2014
There are lots of guys on here with more experience then me, but this is where I am right now with my 62. When it's all done it will be updated to an 80's front and rear suspension, disc front/drum rear brakes, 5 lug conversion, w/ power brakes and existing PS steering re-done.
I bought used parts and spending the time/money to rebuild as I go. Here's what I have bought, w/ part numbers and prices: 81 Front suspension/crossmember/ w/ control arms and all brake parts (used) $200 80's 12 Bolt Rear 3.07 gears /set of Rally wheels $200 CL PS Gear $125 Napa 39-1039 Tie Rod Ends/ Couplers $75 Moog (2) ES409RT, (2) ES409LT (2)ES2004S Booster Mcyl w/ proportion valve Summit- (Right Stuff) G85310971 $170 Booster Bracket/Axle Perches/Steering Plate from CaptnFab on this site. MarkB01 has a great thread on doing the conversion, and there is tons of support here on getting it done. I think it's great that you are getting your son "Actively" involved in doing the project! My son and I are working on mine as well. Good Luck, Pappyx4! |
Thanks guys, I think the way to go is in fact a donor truck. What year span will work with minimal modification?
a-arms and spindles on any thing 71-87 1/2 ton GM. Use the power steering also
SO BUMMED!!!!
So I had a front and rear suspension on hold for Logan, just an hour away from San Antonio. All set to go and pick it up. My buddy found a rolling chassis, that a friend of his had. He said I could get it for the same price. Of course a better deal with all the extra parts like the brake booster etc. So He said to go ahead and cancel with the guy in SA, so I did. Didn't like doing that but I did. We waited for Logan to get out of school so he could go with us and you know, be a part of this deal. So all excited, we head out to where this chassis is. We get there and its a a single axle one ton...UGH...Now we/he has nothing...I feel so bad for him. He just started drivers training a few days ago and was looking forward to getting back on the truck after that... |
Hang in there, You'll find the right donor for your project.
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
So far, no luck....
