Old 04-17-2015, 06:02 PM   #1
Jimal
Jimal's Avatar
Side mount spare tire mount measurement?
Can someone give me the measurement between the stake pocket and the bracket that the tire mount attaches to? I drill tomorrow.
Thanks,
Jim
Jimal is offline   Reply With Quote
Old 04-20-2015, 09:53 AM   #2
1963c-10
1963c-10's Avatar
Re: Side mount spare tire mount measurement?
I can get some measurements for you tonight. The rod coming through the hole on the fender should be centered though.
Heres a good diagram also...
And a good thread on the fender mounted spares: http://67-72chevytrucks.com/vboard/s...=505728&page=7
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-20-2015, 10:05 AM   #3
Jimal
Jimal's Avatar
Interesting. There is also a support bracket at the bottom that I didn't get with the setup I purchased. It looks easy enough to replicate. Something else to do once I get the truck on the road.
Old 04-20-2015, 10:11 AM   #4
1963c-10
1963c-10's Avatar
Yeah, I didn't get it with mine either. Piece of 1/4" thick flat bar about an 1" wide should do the trick if you opt to add it. I never went back and added it to mine. Mines been installed since 2009 and I haven't had any issues.
Old 04-20-2015, 10:59 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
I LITERALLY just set mine on...leveled it and bolted it down without measuring. lol I can easily fit a 31 or eve 32 inch tire on there if I want. With the hole in the fender adjusting can only go so far so its actually kinda hard to mess up. lol In a way.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-23-2015, 08:10 AM   #6
1963c-10
1963c-10's Avatar
Thanks,
Jim
It you butt up against the inner edge of the stake pocket to the center of the bolt hole on the mount I have 6".
Old 04-23-2015, 08:14 AM   #7
Jimal
Jimal's Avatar
Thanks! Now to play Jenga.
Old 04-23-2015, 08:57 AM   #8
1963c-10
1963c-10's Avatar
Helps to have a second hand.....what I did when I did my conversion was to get the mount where I wanted it. Then I marked all the holes with a black sharpie. Removed the mount, drilled all the holes, then reassembled. I did remove the driver side rear fender to drill the inner mount holes.
