Old 04-17-2015, 09:37 PM   #1
scottlogger
front end troubles
hi im new here im in process of putting together a 62 step side i replaced old front end with 78 c10 front suspension everything went in great fit cleaned everything looked good but looking at front wheels on ground the passanger side wheel is sitting out about 2 inches more then drivers side checked frame dosent look bent just looking for suggestions thanks for your help
scottlogger is offline   Reply With Quote
Old 04-17-2015, 11:02 PM   #2
dougf
dougf's Avatar
Re: front end troubles
Is it sitting higher or lower on that side? Maybe the spring isn't in the spring pocket correctly on that side?
dougf is offline   Reply With Quote
