![]() Join Date: Jun 2014
71/72 Gas Pedal On 67
![]() Join Date: Sep 2007
Re: 71/72 Gas Pedal On 67
Where are you going to mount it on the fire wall?
1967custom |
Moderator
![]() Join Date: May 2007
71/72 cable used a ball/socket connection to the carb. That cable pictured has a different end on it and I would guess it is from a 73-up truck
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
That big turn in the cable will wear through the sheath. Or mine did...
#6 | ||
It looks like they made to different ones. 2wd and 4wd. http://sokyclassics.com/product.php?section=1000825 |
Moderator
I'm not sure, but I know it is different. When I get home late tonight I will measure a 71/72 cable if no one else has by then.
Roadtrip!
![]() Join Date: Feb 2003
It looks like you are in the 6 cyl position so you may need the shorter 4x4 cable.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#10 | |
Yes the 73+ cable is longer than a 2wd cable (I verified this past weekend at the junkyard) yes from the factory the original cable had an arc in it, and the 4x4 cable is roughly 2 inches shorter from what I understand.
So do think the 4x4 one is shorter then 10"?
#13 |
Anyone find out what the length is?
#14 |
ttt
#15 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Sorry I didn't understand your PM to my 2012 post.
You can cut the sleeve down and shorten the cable at the pedal. I took 1/2" out of mine.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#16 |
#17 |
Florida Edition
I cut the sleeve at the front, where the mount casting meets the sleeve. 1/2" was just enough to keep the sleeve under tension when you mount it in the firewall I can show you better on my computer tomorrow.
#18 |
I didn't know there were so few sizes used. I needed a non-standard size, because it is for a 4BBL, mounted sideways on a 6 cylinder. I mounted the hanging pedal first, which I would recommend and then collected four different cables from the wrecking yard.
A tight turn shouldn't wear the cable out unless the return spring is too heavy. Mine loops around behind the PCV valve and returns back across the valve cover. Been that way for eight or nine years. If I am recalling correctly, one of the three screw locations that mounted the original '67 throttle arm was reused for the hanging pedal. I don't remember exactly. I do remember that as I was doing it, I was glad the engine was out at the time. There are some holes that need welded closed and three new nuts tack welded in place.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 04-20-2015 at 08:02 PM. |
#19 |
Moderator
Sorry for the delay. Oem 71/72 cable is 20"
