Old 04-17-2015, 11:41 PM   #1
pablo101
pablo101's Avatar
71 directional self canceling lever
My directional lever doesn't self cancel..was this not a standard or is mine broke? If broke is it fixable?
pablo101 is offline   Reply With Quote
Old 04-18-2015, 02:15 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: 71 directional self canceling lever
It should cancel. It could be as simple as replacing a couple of $0.99 cancelling cam springs. See them in this Classic Industries link.
http://www.classicindustries.com/sho...eling%20spring
You can see one this picture. of a tilt column. The other is directly below it hidden by the cancelling cam.
FirstOwner69 is offline   Reply With Quote
Old 04-18-2015, 05:41 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Mine doesnt cancel for the left. Need to oull wheel and check. Do these springs wear out break or what? Maybe came loose?
WIDESIDE72 is offline   Reply With Quote
Old 04-18-2015, 04:30 PM   #4
FirstOwner69
I vaguely remember breaking one years ago. A tilt column I rescued had one missing also, but who knows why.
Old 04-18-2015, 07:53 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Usually the springs break. I have had a couple where the small plastic tab that holds the spring in has broken.
LockDoc
Leon
Old 04-18-2015, 08:10 PM   #6
hugger6933
The "Help" board at the local parts store may be the answer. One of the places that has a large selection of that kind of stuff, should have a turn signal cam and the springs maybe in a pack together. I have seen the cams mess up and not work properly. If they didn't mess up so often why would they be available on the help board. Jim
hugger6933 is offline   Reply With Quote
Old 04-18-2015, 09:17 PM   #7
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
Hugger is correct, I just got turn signal cams from my local Advanced auto
and it came with springs. It's in the red help section.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
