Old 04-18-2015, 08:59 AM   #1
pimpston65
pimpston65's Avatar
calling "6" bangers boys!!!
i fully restored these two carbs only to find one has a bigger bottom butterfly, its going on my 292. how much, if any noticeable performance will be lost if i use the the more yellow cadmium one??? just cuz it looks NOS...
pimpston65 is offline   Reply With Quote
Old 04-18-2015, 09:16 AM   #2
corvettejim1968
corvettejim1968's Avatar
Re: calling "6" bangers boys!!!
if you wanted it NOS looking why not install the nicer looking one and have the one you want replated in zinc or yellow cadmium in the meantime.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 04-18-2015, 10:05 AM   #3
pimpston65
pimpston65's Avatar
do you know of any platers, cuz the ones around me only do big jobs. the ones that will do it want more then NOS...
Old 04-18-2015, 10:47 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Those are two different carbs....one for a 292 and the other probably for a 230 or 250. Yes you will loose power with the smaller butterfly....less air flow. Both look stock to me so I'd use the bigger one.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-18-2015, 11:18 AM   #5
pimpston65
pimpston65's Avatar
thks TJ, the nicer one is from a 230, dang it!!! the 292 one just looks lame next to my fresh paint, i did see one claiming to be 292 NOS and it was yellow cad. i think mine is just faded...
Old 04-18-2015, 11:40 AM   #6
bullwinkle3331
Maybe a stupid question, but shouldn't you be able to take the bottom section with the bigger butterfly and mate it to the newer cad plated upper carb section?
With that said - you may not want to because they look different in coloration...
bullwinkle3331 is offline   Reply With Quote
Old 04-18-2015, 12:10 PM   #7
pimpston65
pimpston65's Avatar
its a smart question, but thats what my plans were. thats how i found out they are different, plus the nicer one has passageways miled into the bottom between the cast iron mounting piece, so i dont wanna cuz issues. ima take them both to my carb guy and see what he thinks!!!
Old 04-18-2015, 12:13 PM   #8
pimpston65
pimpston65's Avatar
the airhorn or top piece has the same part number so that wouldnt be a problem with swap, it dosent look as nice thou. im going for looks and function!!!
Old 04-18-2015, 01:42 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
This is the place I used in the past and have suggested to people. They'll restore your carb with the proper plating as well.
http://www.carbrebuilders.com/aboutus.htm
Old 04-18-2015, 07:03 PM   #10
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Why not get yerself a good rebuilt one from Autozone? Color don't matter cause they were grey anyway. Least the one that was on my 292 is.
Old 04-18-2015, 07:32 PM   #11
pimpston65
pimpston65's Avatar
it does look as good as the yellow cad one
Old 04-18-2015, 07:35 PM   #12
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I think you meant "doesn't" so my reply. lol THEN PAINT IT YELLOW!!!!
Old 04-18-2015, 07:50 PM   #13
pimpston65
pimpston65's Avatar
i figured it out, i took the top(airhorn) which is same part# and added it to the 292 bottom and base!!! then i put the levers from the nicer one. looks and workd perfect!!!
Old 04-18-2015, 07:51 PM   #14
pimpston65
pimpston65's Avatar
got the nos look now!!!
Old 04-18-2015, 08:58 PM   #15
pimpston65
pimpston65's Avatar
thks for the idea, it worked!!!
Old 04-18-2015, 09:20 PM   #16
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looks very nice! I'm gonna have to subscribe to yer build so I can see more pics! lol
Old 04-18-2015, 10:00 PM   #17
pimpston65
pimpston65's Avatar
the build is gonna be as correct as possible, thats why i wanna get it right once. kinda intense, but thats what i wanted...
Old 04-18-2015, 10:01 PM   #18
pimpston65
pimpston65's Avatar
i want this burban to look brand new, so every piece is getn then same treatmemt!!!
