68 C 10
![]() Join Date: Aug 2010
Rear bag brackets
My setup right now is
1) PB C-notch 2) PB 3 inch drop tubular trailing arms Switching over to air bags from coil springs. What I'm wondering is will I still get plenty of drop with the bags mounted in the brackets then to the frame since I have the c notch and 3 inch blocks. Or would it be better to drill the holes in the frame and mount them straight up to the frame.. Thanks. Kevin
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Rear bag brackets
Kevin,... Your air bag compressed is about 3" tall.
Stick a 3" block of wood (or the bag if you have them) in place and see how far it airs out. I think you will fine with the upper bag brackets and your PB trailing arms.
68 C 10
Thanks Keith never even thought of just sitting the bag in there. Sometime just the most simple things work best lol and sometimes I over think it lol
Kevin
