04-18-2015, 06:12 PM | #1 |
Modern seat ideas
I would like to run with front buckets from a later tahoe for my 72 blazer because of the built in seat belt but i noticed everyone is usually getting 2nd row..I guess because of the bracket height and flips up? Does anybody know of any front seats off later chevys, tahoes, yukons that have the seat belt built in and will still fold or slide forward for rear access? Or am I just asking for to much?
04-18-2015, 07:13 PM | #2 |
Re: Modern seat ideas
I've seen just about every seat put in that I can think of. Only thing I don't like about the newer seats is they stick up really high especially with the built in seat belts. I have bestop front seats in mine and they are high but they don't look too bad since they sick up where the roll bar comes down. I'm sticking with the stock rear seat.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
04-18-2015, 07:33 PM | #3 |
can you post pics of what your seats look like? What kind of brackets did you use?
04-19-2015, 05:57 PM | #4 |
Its lookin' like a Blazer!
You can take a look through my build thread, I think there are seat pics around the middle and with covers towards the end. I used seats out of 2000 and later
Silverado and the third rows out of a Tahoe. Both have built in seat belts. Just make sure to reinforce the floor where they bolt up. Ya don't want the seats ripping the bolts through the floor in an accident. |
04-19-2015, 06:04 PM | #5 |
I used the stock brackets just made some plates to bolt them to.
04-21-2015, 01:38 AM | #6 |
Those look good i believe thats what I will go with. I already have the factory passenger bracket I will just need to get a drivers.
04-21-2015, 09:12 AM | #7 |
Trailblazer ss seats have built in belts, mount them slid all the way back so you have some room to slide them forward.
1968 k10 lwb-swb stepside 1936 chevy truck 1977 corvette My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176 1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824 |
05-07-2015, 11:38 AM | #8 | |
http://image.trucktrend.com/f/roadte...ront_cabin.jpg Those aren't a bad looking seat - belt tower is low to the seat and removable headrests to look even closer to stock 69-72 Blazer seats. |
05-09-2015, 05:49 AM | #9 |
Collector of Projects
04-21-2015, 10:17 PM | #10 |
They are pretty comfortable and summit racing sells a few different types. I want black eventually so I may pull these out and sell them to get the black ones.
04-22-2015, 05:59 AM | #11 |
I used manual seats from a 2006 Chevy truck. I have seen others used 2nd Row captains chairs from a Tahoe/Escalade because they have a flip forward mechanism from the factory... what aver you do, make sure you renforce the floor from underneath because if you have an accident that it the only thing from keeping YOU and the SEAT from going through the windshield...
04-24-2015, 11:42 PM | #12 |
I used the front seat row out of a 1998-2001 Dodge Ram club or extended cab( quad cab seats don't slide forward enough). They have built in seat belts and slide forward for rear seat access. A bit tricky install, but I couldn't be happier.
05-05-2015, 07:22 PM | #13 |
BlazerOwner, What year bestop seats did you order for? I seen they have different year models for the jeeps and didnt know if certain ones were easier to mount or not. Thanks Also do you have pics of the plates you made to mount them?
05-07-2015, 02:04 AM | #14 |
The seats are all the same, I believe it's the seat mounts that are different that you buy seperately. Basically the mounting holes are straight down in the seat so all you have to do is make a plate for the difference in where the original mounts would be. I actually have plans to make a better setup so I have already tossed the plates I made as I didn't think it was safe enough. These are going in the for sale pile soon I want to get the black ones. I have a set of 2010 Camaro seats in my Chevelle and they were much harder to adapt. These are a piece of cake in comparison.
Kirk 72 Blazer CST 4wd highlander 66 Nova Last edited by Blazerowner; 05-07-2015 at 08:27 PM. |
05-07-2015, 09:22 AM | #15 |
OK thanks
Posted via Mobile Device |
05-11-2015, 10:47 AM | #16 |
MCMIXIX, do you know if you can still buy those 2nd row captain seats for 200? Everywhere I have seen are 800 to 1200 for a set.
05-13-2015, 05:52 AM | #17 | |
http://sandiego.craigslist.org/csd/pts/5016495623.html http://losangeles.craigslist.org/lac...018811614.html http://atlanta.craigslist.org/atl/pts/4966071214.html http://atlanta.craigslist.org/sat/pts/4955772050.html Last edited by mcmlxix; 05-13-2015 at 06:06 AM. |
05-13-2015, 05:09 PM | #18 |
Ok Im going to go to the goodguys show in Nashville this weekend and try to find something.
