04-18-2015, 08:34 PM | #1 |
Looking for opinions on Magnaflows
Yes this is another muffler question, but kind of specific.
My current setup is a 5.3, shorty headers, 2.5" mandrel pipes, X-pipe, and 2 15x8x24 Magnaflows with dumps in from of the rear axle. I've had this setup for about a year and a half as a daily driver, and it's very nice but just too quiet for my liking. Recently just for fun I put some straight pipes in place of the mufflers, and although it sounds like a race car it's too raspy and obnoxious at times. I'm thinking about getting the same Magnaflow mufflers but either the 14" or 18" body this time instead of the 24", and I'm looking for opinions as to how much of a difference there is between them, if anyone has tried them. Thanks
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
04-18-2015, 10:17 PM | #2 |
Fabricate till you "puke"
Re: Looking for opinions on Magnaflows
I run a 14" body (single), on my 02 Silverado, & it has a nice sound....not loud enough to give you a headache, but enough to hear it. On my 69, with 5.3, I run 2 1/2" duals/H pipe & 50's Flow masters. I also run street rod shorties, with mandrel bent downs. My tail pipes are 'crush bent", but with easy bends (I built them myself ), & they exit the rear of the truck through the rear bumper. Awesome sound! IMO, to get with the "right sound", you need to loose the dumps, & run the tail pipes out. If you want to hear it good, I would go 14" on the muffler body. Placement, fore/aft will also change the sound.....generally, move em forward to make em "bark", or rearward , to tame the note ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-18-2015, 11:16 PM | #3 |
While I haven't installed it all yet, I have the 14" body 3" in/out magnaflow single pipe exit system going in my 76 with a 4.8l swap. I hate the drone of a Flowmaster and heard a lot of good things about the Magnaflow. I am in the process of building a 2.5" y-pipe to a Magnaflow 2-in-to-1 3" out y-pipe adapter. I am hoping for a good sound with out the drone.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-19-2015, 12:27 AM | #4 | |
04-19-2015, 01:07 AM | #5 |
I just went on a cruise with my bro-in law in his 2002 silverado with Flowmasters and was reminded of why I don't care for them. I promptly bought the Magnaflow. Hoping to get it installed and fire it up soon, with in the next month.
I have heard 5.3l trucks with true duels and no mufflers and I don't think I could drive a vehicle like that for any period of time. I like a vehicle I can cruise and have some good sound.
04-19-2015, 01:58 AM | #6 |
meowMEOWmeowMEOW
I've got a pair of Mag's bullet-style mufflers/resonators on my lq4. My engine sounds a bit different since there isn't a crossover and it exits before the wheels, but the actual exhaust is pretty good. My lack of X means its a bit snappier and aggressive, but doesn't "burble", and does tend to drone a bit on the hwy.
The mufflers themselves are pretty decent, and the small form factor on the ones I used makes mounting them easy. I'd say my truck is probably 10% louder than I'd like, but with my configuration, that may be unavoidable.
04-19-2015, 05:38 PM | #7 |
Longhorn, I understand what you mean about running the pipes all the way to the rear. Unfortunately I can't, due to the truck being lowered 5.5" in the rear and having a 25 gal. square body tank behind the axle.
04-19-2015, 05:40 PM | #8 |
And the main reason I'm only considering Magnaflow is because of how impressed I was with the quality of the mufflers, as far as construction and sound control of the mufflers.
04-19-2015, 07:44 PM | #9 |
I hear you brother, it is hard to reinvent the wheel....& spend a bunch of money! What if you turn out the sides, ahead of the wheels? Add a set of 16" long "/3"diameter "cans" in chrome or stainless....can you hear me now? You might opt for the 18 " body mufflers on that app Longhorn
04-22-2015, 12:31 PM | #10 |
So I know that video clips of exhaust sound don't always do justice for how it actually sounds, but I've been watching a few videos of magnaflows, flowmasters, and borlas on 5.3's, most of them with cats of course, and it really sounds like the borlas have the deeper sound I'm looking for rather than the magnaflow. Even the 14" magnaflow still seems too quiet.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 04-22-2015 at 12:39 PM. |
04-22-2015, 01:09 PM | #11 |
meowMEOWmeowMEOW
Borla spends their entire R&D budget on making their exhausts sound deep, and I'm not joking about that. Its their signature thing, the low drum followed by the burble.
If you listen to exhaust clips online, I strongly suggest considering the source. If the video was recorded on a phone, or camcorder, then your missing 30-40% of the actual sound spectrum (audio is instantly compressed and has built in HPF/LPF to prevent clipping). Compare that to something like GymKhana (the Ken Block thing), which is full-budget and each car is mic'd for independent sound. I've had friends hear something online, put it on their car, and sound NOTHING like what they thought. I'm finishing some editing but I have a few idle clips of my truck through my Rode prosumer Mic that I'll put up in a little once I finish. Oh and don't listen on laptop speakers
04-22-2015, 07:16 PM | #12 |
Old member
I have 2.5" full dauls on my LQ4 Ls 6.0 with long tube headers and megaflows. I like it a lot. They are quit when idling but when you step on it you hear it! That's what I wanted anyways. Understan that this is without any music either!
04-22-2015, 08:17 PM | #13 |
I have been running a Magnaflow 18" body oval muffler, with 2.5" dual in, 3" single out. With longtube headers on my TPI 305, it's got a good rumble at idle, yet it's fairly quiet. When you get on it, it gets loud, but not obnoxiously loud if you know what I mean. No drone in the cab at all. Love it and plan on re-using the same exhaust with the 5.3L that going into the truck.
04-23-2015, 12:03 PM | #14 | |
04-25-2015, 06:40 PM | #15 |
meowMEOWmeowMEOW
Here is the startup and idle after sitting for 5 months. There is still a bit of audio compression from putting it on YT, but its better than the other clips I have. (its also sitting in a garage).
If weather improves I'll back it out of the garage and point the mic at the exhaust dumps so you can actually here what it sounds like off-idle.
04-29-2015, 09:56 PM | #16 |
BR3W.....that's nice! Can I ask what you are running on the camshaft? Longhorn
04-30-2015, 12:02 AM | #17 |
meowMEOWmeowMEOW
From "Birth" to now, its been on a Texas Speed Tsunami (111LSA)
In a few weeks, we may be updating to a newer cam profile.
05-09-2015, 11:10 PM | #18 |
So I welded up my y-pipe and "loosely" installed the 3" magnaflow from summit. While my truck is still in the air, I can idle and rev it up. I could not be happier. It is surprisingly quiet at idle and when I rev it up it gets a great sound to it.
The best part was the smile on my wife's face and when she asked when "her" truck was going to be done. I would highly recommend this muffler. Matt
05-11-2015, 04:44 PM | #19 |
I went with borla for the sound 2 1/2" to the rear 69 suburban. Quiet idle and rumble with no gurgle when I'm heavy in the throttle
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
