08-30-2003, 05:48 PM | #1 |
Hard starting bbc when hot.
Just picked up a 72 402/400 over the weekend and noticed it barely starts when it gets hot. It starts just fine cold, but hardly cranks at all when warmed up. Any ideas?
Thanks. |
08-30-2003, 05:51 PM | #2 |
Inline 69
put a heat shield by the starter,my old pontiac did that, i tried replacing the starter,but it still did it
08-30-2003, 05:55 PM | #3 |
Inline 69
pic #1
08-30-2003, 06:02 PM | #4 |
Inline 69
heres the shield
pic#2
08-30-2003, 06:06 PM | #5 |
Inline 69
3
ill get the link ,,,,,good luck,,,,jeff
08-30-2003, 06:07 PM | #6 |
Thanks! Any idea of where I can get a shield?
08-30-2003, 06:24 PM | #7 |
Inline 69
you can get them at any speed shop,but heres for moroso type,#74300 http://www.moroso.com/catalog/catego...?CatCode=42022
08-30-2003, 06:43 PM | #8 |
Fabricate till you "puke"
That one confuses this old man.... I have run BB olds, BB caddy, & big inch sb in my truck. a good battery, good set of cables, & a good starter are the ticket. im not tryin to start a fight, but if the fore mentioned parts are in good shape.....I havent seen a problem I have also run headers on the Olds, & the Chev(2 of them in the longhorn)......no sheilds , or remote solenoids....no problem. the 461 Olds ran @ 9.8 on comp ratio, as does the 383 Chev(alum head on the chev helps), but I dont see the problem that many guys have stated......perculated fuel, yes I have seen that problem. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-30-2003, 07:01 PM | #9 |
this may confuse you, but my 72 did it and it turned out my timing and points were off
70 longbed 496/th400/Ford 9" |
08-30-2003, 07:14 PM | #10 |
Inline 69
come on guys,,,he asked for ideas! so i was helping him out,my idea isnt so far out in left field,,,,,,jeff,,,,,
08-30-2003, 07:33 PM | #11 |
No trouble Jeff.....he asked for ideas, & I gave mine ......Im not tryin to "stirr" a problem, but havent seen the problems that MANY guys talk about? crazyL
08-30-2003, 07:46 PM | #12 |
My old Pontyrat did the same thing. It was Ok after I replaced solenoid. The heat shield does help..so I'm told...with the starter & solenoid prematurely wearing out because of heat. I never used one, so I can't say if they would have made a difference or not.
08-30-2003, 08:35 PM | #13 |
Robert Olson Transport
you may wanna lookinto a heavy duty starter too with the heat shield
08-30-2003, 08:39 PM | #14 |
Thanks for everyone's input. I just got the truck and haven't had the chance to check it out yet. I know the timing was off when I got it, had to advance to spot it from popping (HEI). I got several milk crates of parts, and although I haven't gone through them I did notice an old starter. Oh yea, it has headers also.
The shield sounds like a good way to start, not expensive and can't hurt. Thanks again. |
08-30-2003, 09:33 PM | #15 |
Glowing since 1978
The big block 454 in the vette was factory equipped with a heat shield and a hi torque starter. It does make a difference. It absorbs the radiant heat from the headers as long as there is an air gap between the shield and the starter.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
08-30-2003, 11:35 PM | #16 |
its all about the +6 inches
You'll be best off puting a new starter under that new heat shield too. The damage is already there.
I've lost one starter to my headers, and seen plenty more. In the newer Grumman delivery trucks with the GM 6.2/6.5, they come stock with the heat shield on them. |
09-01-2003, 10:22 AM | #17 |
Definitely do the starter thing. But don't forget to check the timing & advance. Make sure vacuum isn't getting trapped in the hose to distributor & holding the advance to max position. Thermal vacuum switches can do strange things.
'72 Longbed 2WD Mostly used to hide under from the wife & kids. (But coming along nicely) Southampton, PA '87 Chev 1-Ton 4X4 '52 Ford F1 '97 Harley " No Falls... No Balls ! " |
09-01-2003, 10:30 AM | #18 |
GEARHEAD
This happened with mine too. The timing was advanced too far. I turned it back a few degrees and hot restarts are no problem.
HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
09-01-2003, 03:06 PM | #19 |
Check to make sure your ground straps are good, a bad ground will overheat the starter also
Rest in Peace Ed. Thanks for all the good times. |
09-01-2003, 05:29 PM | #20 |
Check the battery cables also
