Which Radiator ? 2 or 3 row, Aluminum ?
My engine replacement has turned into a restoration than just a new crate engine. I keep finding parts either worn completely out or broken. I'm the type who doesn't put this off. I will update my engine thread later.
What I need input on is what size Radiator to buy. The one that came out of the truck looks to be OEM. And weights a ton, its plugged up. And the bottom half is soft. Its a three row also. I'm looking at replacements and with the new Aluminum Radiators out there is it possible a two row will do the job of the old three row ? Or stay with a three row ?
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
| Bookmarks |
