Old 04-19-2015, 03:04 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
Brake line adapters
I am do a front disc brake conversion on my 70 c10 and have hit a snag. I had to change to a proportion valve and my brake lines don't fit. I don't want to change my lines right now, so I was looking for some adapters. From what I can tell, my proportion valve has a 3/8-16 port for the front brakes and a 9/16-18 port for the rear. My brake lines are 7/16 for the front and 9/16 for the rear. What would be the best way to go about making this work? Thanks.
Kaptain Kadian is offline   Reply With Quote
Old 04-19-2015, 03:20 PM   #2
Aruba1
Re: Brake line adapters
I took my MC, lines and proportional valve to Napa and they gave me the right adapter.
Aruba1 is offline   Reply With Quote
Old 04-19-2015, 07:02 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Brake line adapters
Any parts store should have adapters for you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-19-2015, 07:05 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
You need "inverted flare" adapters from your parts store.
Speedway Motors also sells them.
Keith
Convert to disc brakes.
Old 04-19-2015, 07:53 PM   #5
Ruscal
Possibly you could cut off the flare on the front line, slip a new 3/8 fitting on and re-flare?
Russ
Ruscal is offline   Reply With Quote
Old 04-19-2015, 10:54 PM   #6
Kaptain Kadian
Thanks guys. My new master cylinder should be here by the end of the week, and I will just take everything to the parts store and hopefully get everything to fit together.
