04-19-2015, 03:11 PM | #1 |
Cam choice
64 c10 355 sbc, what cam your you guys running to get these heavy trucks rolling.
One I have doesn't seem ton work very well. 355 sbc 215 / 64cc alum heads Isky 530/550 232/246. 282/292 @.050 110 lobe center Also I have a 750 demon, was told these were much bigger than a 750 Holley, this may be my problem Any input would be great. Jeff |
04-19-2015, 06:21 PM | #2 | |
Re: Cam choice
04-19-2015, 06:26 PM | #3 |
Re: Cam choice
What tranny, rear gear and tire size you running?
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
04-19-2015, 07:16 PM | #4 |
Re: Cam choice
350 trams
373 gear 28.5 tall tires 2500 to 2600 stall Hoping its the carb |
04-19-2015, 07:58 PM | #5 |
Re: Cam choice
I think you have too much cam for your converter and gears.
That's a 3000-7000 power range cam With those tall tires I would go with a milder cam or drop to 4.11 or 4.33 and move to a 3000 converter, that's a fair amount of weight your trying to move. There's a lot of other variables such as ignition, timing, carb, exhaust JMO Good luck,Bud |
04-19-2015, 08:46 PM | #6 |
Re: Cam choice
bud 56 , you are correct on cam,
Im gonna try a diff carb, have not had much good feed back on the demon carb, ive always run quads or holleys, was told a 750 demon flowed more like a 850 , maybe it to much, hate to tear a motor apart for a carb fix, thanks |
04-19-2015, 10:08 PM | #7 |
Re: Cam choice
I have a 355 in my 1964. Xtreme Comp Cams 286 duration and about 485 lift. Was running a 750 Edelbrock carb originally but it was too much and switched to a 650. Stock heads from the 283 that came out of the truck. 2.5" headers and exhaust. 5-speed manual tranny with 3.73 gears. Sounds good. Runs good. Launches like a bat out of hell.
[IMG][/IMG] |
04-19-2015, 10:34 PM | #8 | |
Re: Cam choice
What's initial? How much in the mechanical? Vac advance, how much and which port? |
04-19-2015, 10:51 PM | #9 |
Re: Cam choice
12 to 14, no vacum, total is 36 to 38, vacum was pulling it to 58
04-19-2015, 11:37 PM | #10 |
Re: Cam choice
So you got 24 in your dizzy. And likely a lazy curve.
You need 16 to 18 initial. Limit your dizzy to 16. Limit your vac advance to 12. That'll wake it up. http://www.crankshaftcoalition.com/w...EI_distributor |
04-20-2015, 12:57 AM | #11 |
60-66 Nut
Re: Cam choice
The other thing that is hurting your engine's low end torque output is those heads. A head with 215cc intake ports is way too big for a streetable 355.
