Old 04-19-2015, 04:08 PM   #1
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Door cuts anyone?
I have 2 door that I about to scrap, before I just toss them I thought I would offer them out. If anyone needs some cuts from these let me know and I will see if I can help you out. You just pay for shipping of anything you need.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-19-2015, 04:36 PM   #2
lchall
Re: Door cuts anyone?
I could use the door bottom from the first picture assuming its pretty good across the front. Need to patch up some speaker holes the PO butchered into the doors. Circled in green.
If you could cut along the line where the door panel would start then all the way around the bend that would be great. Really just need the face of it. PO had put a 6x9 in each door and even got down into the raised area on the bottom. Can cut in half (top/bottom) if that helps with shipping. Would be shipped to 63303.
Thanks - Chad
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 04-19-2015, 05:07 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Lower door panel nuts in good condition?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-19-2015, 05:14 PM   #4
chevytruckluver
Attachment 1392909
Thanks - Chad
That's why the other door has the same section missing...haha
I will cut it and box it and get you a price
Trey
72 Short Step
Old 04-19-2015, 05:16 PM   #5
chevytruckluver
No sorry
Trey
72 Short Step
Old 04-19-2015, 05:21 PM   #6
Woodnears
I would be interested in the bottom I side and out of a couple doors if they aren't rusted or beat up too bad.
Woodnears is offline   Reply With Quote
Old 04-19-2015, 05:22 PM   #7
Undone
How are the door bottoms?
Undone is offline   Reply With Quote
Old 04-19-2015, 06:12 PM   #8
chevytruckluver
Attachment 1392909
Thanks - Chad
Hey Chad I made the cut, there is an inner reinforcement that I had to drill out 3 spot welds. will look for a box tomorrow
Trey
72 Short Step
Old 04-19-2015, 06:38 PM   #9
lchall
That looks perfect. Thanks a lot. Just let me know what I owe you.
Thanks - Chad
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 04-19-2015, 06:45 PM   #10
chevytruckluver
Updated pics after some cutting.
undone, woodnears do you see something you can use?
Trey
72 Short Step
Old 04-20-2015, 11:43 PM   #11
ls1nova71
ls1nova71's Avatar
I could use the front corners of both doors. I have some 2 ton doors I need to convert back to 1/2 ton doors. They don't look rusty, are they bondo'd up or anything?
This part. Let me know how much, Thanks.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-21-2015, 06:05 PM   #12
chevytruckluver
The inside is not rusty, the outside has been worked some but I don't know if its just a skim coat, I will cut them off and see what happens, will let you know!
Trey
72 Short Step
Old 04-21-2015, 06:43 PM   #13
ls1nova71
ls1nova71's Avatar
Cool, the inside part is mainly what I need, I can make a patch for the outside if I have to. Let me know how much. Thanks.
Old 04-21-2015, 07:34 PM   #14
chevytruckluver
Here is the cut part you asked about on the 3rd pic you can see a dent with a little rust but since you will be able to get to the back of it now it may be ok.
Let me know
Trey
72 Short Step
Old 04-21-2015, 10:23 PM   #15
ls1nova71
ls1nova71's Avatar
Thats really more than I need and will probably be harder to ship. All I really need it this much, but if it can be shipped reasonably I will take them that way so you dont have to mess with cutting them again. Just let me know.
Old 04-22-2015, 07:23 PM   #16
chevytruckluver
pm sent
Trey
72 Short Step
Old 04-22-2015, 09:28 PM   #17
UP GRADE
one set closer
UP GRADE's Avatar
Hey chevytruck I could use this part. It's on the driver door it's the upper piece where the door hinge bolt to.
[/IMG]
UP GRADE is offline   Reply With Quote
Old 04-22-2015, 11:07 PM   #18
chevytruckluver
[/IMG]
Ok, so you need a couple of inches above and below the hinge? and just the driver's door correct?
Trey
72 Short Step
Old 04-23-2015, 11:55 AM   #19
UP GRADE
one set closer
UP GRADE's Avatar
Yes mine is rusted out.
Old 04-24-2015, 08:33 AM   #20
chevytruckluver
Okay, I got this cut out for you. If you think that will work for you let me know
Trey
Trey
72 Short Step
