Old 08-30-2003, 06:15 PM   #1
john8746
john8746's Avatar
wiring nelp
Does any one have a wiring diagram for the engine
for a electronic ignition. Can't get the truck to start with the key
I'm just lost HELP. changed from point to electronic ignition
C/10 John N.J.
john8746 is offline   Reply With Quote
Old 08-30-2003, 06:48 PM   #2
cdowns
cdowns's Avatar
first thing is you eliminate the yellow wire at the starter, then you take the yellow wire at the coil go back thru the wire loom find the spot in the firewall junction box it goes to then remove it and replace it with a new length of 12gauge wire and you'll be good to go . the reason you have to replace the original is that the original wire is a resistor and only supplys 7volts to the coil
Old 08-31-2003, 01:17 AM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
Check FAQ http://67-72chevytrucks.com/vboard/s...threadid=13698
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 08-31-2003, 01:19 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do you have the wire in the proper terminal on the HEI cap?
If everything looks good, then check your plug wires and make sure the fireing order is right and that they are in the correct location.
