Old 04-19-2015, 06:50 PM   #1
Jimal
Jimal's Avatar
Step fender bracing
I'm a gas tank away from getting my truck on the road in time for its 50th, and one of the final, non-gas tank pieces of the puzzle is the bracing for the rear fenders.
From what I can tell (thanks LMC), there should be three braces per side; two on each wheel arch that attach to the fender mounting flange, and a third that attaches behind the wheel arches to somewhere. I've figured out three of the four arch braces (and assumed that the side mount spare tire bracketry will come into play on the fourth) but I haven't figured out what the last two braces attach to, if they're supposed to be there at all.
These are the pieces I have:
But when I mock them up, they don't seem to line up to any existing holes, but they do happen to line up with the bed wood, meaning nutting and bolting is out of the question.
What am I missing?
Jimal is offline   Reply With Quote
Old 04-19-2015, 08:09 PM   #2
pimpston65
pimpston65's Avatar
Re: Step fender bracing
should be 4 a side one in the back 2 around the arch and one the attaches to area where the step meets the fender and goes through the frame...
pimpston65 is offline   Reply With Quote
Old 04-19-2015, 08:12 PM   #3
pimpston65
pimpston65's Avatar
i seen its got 66 fenders!!!
Old 04-19-2015, 08:41 PM   #4
Jimal
Jimal's Avatar
That would explain the taillight provisions in the fender.
"Where the step meets the fender and goes through the frame."
Can you explain that one?
Old 04-19-2015, 08:47 PM   #5
pimpston65
pimpston65's Avatar
on the inside of the fender, there should be an area where the fender meets the back of the step one of the bolts that attach the 2, one is the brace rod instead of a bolt. well that rod has a threaded end that goes through the frame with a nut on the other side...
Old 04-19-2015, 09:07 PM   #6
Lugnutz65
Lugnutz65's Avatar
My 1965 fenders.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-19-2015, 09:10 PM   #7
pimpston65
pimpston65's Avatar
Originally Posted by Lugnutz65 View Post
My 1965 fenders.
my 65 has an additional brace the goes in the same location where the step meets the fender, on the inside of course!!!
Old 04-20-2015, 08:46 AM   #8
Jimal
Jimal's Avatar
My 1965 fenders.
So the braces I have to go there. Maybe with a bit of massaging I can get them below the wood where they attach to the bed side.
I don't think I have anything like this in my small stock pile. Back to digging tonight.
Old 04-21-2015, 09:13 AM   #9
Jimal
Jimal's Avatar
I dug through my increasingly shrinking pile of parts last night and didn't find a brace like what is pictured on the step end of things. I do remember seeing a brace like that at one point, but I can't lay my hands on it now.
I did lay my hands on a few of the back of the quarter braces, as well as a couple shorter braces that I haven't figured out where they belong yet, if they belong.
To the Classifieds!
Old 04-21-2015, 04:35 PM   #10
forestb
forestb's Avatar
Mine connected with a bolt that went through the bed side and through the L shaped peace that is welded to the bed side that holds the edge of the wood down. I reallocated mine to one of the rails that the wood lays on by creating my own brackets out of tube stock with clamped down ends.
forestb is offline   Reply With Quote
Old 04-21-2015, 05:34 PM   #11
Joe Pass
Joe Pass's Avatar
Here is the brace position installed on my 62 ...the third picture is a long 1/4 dr extension sitting were the step brace should go when I score one
Joe Pass is offline   Reply With Quote
Old 04-21-2015, 07:47 PM   #12
pimpston65
pimpston65's Avatar
[QUOTE=Joe Pass;7142856]Here is the brace position installed on my 62 ...the third picture is a long 1/4 dr extension sitting were the step brace should go when I score one
if you dont find one you can make it, use threaded rod for the frame side, weld it to round stock and weld the bent end that attaches to the fender/step portion, if u have extra rods just cut the end with the smashed area that has the bolt hole and weld it up. thats how i made my side mount spare holder from 2 units to make one!!!
Old 04-22-2015, 08:51 AM   #13
Jimal
Jimal's Avatar
These are a help, thanks. I have two brace (4 actually) that will work for that rear most position.
