Question on a Build Sheet
I have a 68 C10 LB with a build sheet or options sticker in glove box that was painted over. I took Goof Off and cleaned it off to a point that any more cleaning would take the options off. What was left after the cleaning wasn't real readable. DOES any body know how to get the build sheet for my Truck or where to start looking for it if at all possible. Thanks in advance. mjgord51
![]() Join Date: Aug 2008
Re: Question on a Build Sheet
In seat springs either back know or bottom, behind gas tank or under floor mat.
#3 | |
The build sheet itself exists only in the vehicle if at all so if you can't find it there then it is no more. Now - on the other hand - the build content/invoice may be available through GM of Canada if your truck was built in Canada or if it was built domestically for Canadian sale. Search for Vintage Vehicle Services (GM of Canada). The GM Heritage Center archives house information only for US built and sold vehicles, starting in about 1976 for pickup trucks. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Also - post up what you have, and your interpretation.
Some folks here have the RPO codes memorized and we may be able to piece together what you have using context clues. K
![]() Join Date: Apr 2014
Many of us (me included) are missing pieces of or the entire build sheet. One guy mentioned look for it in springs or under floor mats. The glove box is another option. Beyond that... Not good news.
1967 C10: My next project 1964 SS Impala Hardtop, low and slow 2007 Harley Street Glide .... When all else fails to start. |
Old Duffer
![]() Join Date: Mar 2003
IIRC the build sheet and the "SPID" sheet are two different documents. Coming across the build sheet is far rarer then the SPID.
If you contact the Chevrolet Customer Assistance Center they may be able to help if you give them your VIN. 1-800-222-1020. I don't know if this is still in operation, but it was a couple of years ago. Good luck!
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." Last edited by slomotion; 04-21-2015 at 06:10 PM. Reason: Added information |
Thanks I'll try the phone # and search for the V.V.S. GM of Canada
Unless your truck was built in Oshawa (plant code 1) for the Canadian market there is little point in contacting VVS or spending the $75.
http://www.vintagevehicleservices.com/options.html Have you decoded the VIN? http://67-72chevytrucks.com/vboard/s...d.php?t=570059 Can you get some good pictures of the SPID? Often a separate left and right half work best when faint. http://67-72chevytrucks.com/vboard/s....php?p=5659580
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
