04-19-2015, 10:33 PM | #1 |
Lowered 71 2wd. Advice
Hello guys, so I did a c notch because I was banging on the frame. I installed 5" drop coils in the rear and have a 2" block. It looks higher than it was??? I want to go lower. I thought 5" couls were the lowest I could buy. Should I hear them? Has anyone ever tried this? Any other suggestions would be appreciated. I've thought about doing bags I'm just not there yet..
There is about a 3" difference from the front and rear. I would like to get to about a 1" difference. Thanks |
04-20-2015, 10:50 AM | #2 |
Re: Lowered 71 2wd. Advice
I wouldn't heat them, ECE has 6" drop rear coils for another inch. I have the 6" coils on my Blazer without the 2" blocks and I find the ride to be as good or better than stock.
How low is the front for you to have such a big difference? Do you have taller tires on the rear?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
04-20-2015, 11:51 AM | #3 |
The front is 5". And yes I have a taller tire. I guess that's the problem.
I thought it would look good with a little taller tire but I guess not. I'll probably try the 6" |
