Old 04-19-2015, 10:48 PM   #1
schetk
Loose steering wheel
I have a 63 c10. I took the column apart to paint. Floor shift
The middle section with turn signal is tight. But when I puth the horn contact bearing piece on, seems to be tight, but after I tighten wheel, I get a loose steering wheel ? The 60-66 manual shows a spring somewhere but I don't remember having one, what am I doing wrong?
schetk is offline   Reply With Quote
Old 04-20-2015, 09:25 AM   #2
1963c-10
1963c-10's Avatar
Re: Loose steering wheel
The only spring I'm aware of internally is the horn plunger and the spring for the shift arm on an auto or column shift. Is it just the steering wheel that's loose? I'd think it might be a missing insulator.
Is it the standard wheel or the custom wheel? And was it tight prior to disassembly for paint?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-20-2015, 10:16 AM   #3
Figuarus
Figuarus's Avatar
you're sure it's not in the gear box or the tie rods? when you say loose, do you have wobble in the wheel, or during rotational movement?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 04-20-2015, 11:36 AM   #4
sambrutay
sambrutay's Avatar
lower column see #19
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
Old 04-20-2015, 05:30 PM   #5
schetk
the steering wheel it self has movement in all directions after i tigthten the nut #29.
it is tight on the shaft but feels like it moves an 1/8 th inch in either direction.
on the chart picture you sent, it feels solid through number# 36 signal housing, but i guess the upper bearing is all there, is there a test for how much slack should be here?
also, is there an adjustment on #18 through #26 at the other end?
Old 04-20-2015, 10:22 PM   #6
vince1
If the upper and lower bearing are good and the spring 19 is under compression from the coupling clamp and bolt below it, the steering wheel will not be loose.
vince1 is offline   Reply With Quote
Old 04-21-2015, 02:47 PM   #7
AnlaufJohn
I have a loose steering wheel, too, and I suspect my upper bearing has slipped out of the turn signal switch. I have a new switch/bearing kit and hopefully, this new one will allow the cancel function resume its purpose in my truck.
In the photo, I am referring to #34 & #33.
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
AnlaufJohn is offline   Reply With Quote
Old 05-23-2015, 05:26 PM   #8
Metalaroundstone
See my post "When is a steering shaft toast" that I posted today to see what a bad lower bearing can do to your steering shaft. My steering wheel seemed to have too much side-to-side play, but the upper bearing looked okay. I just got around to checking the lower bearing, which was totally disintegrated. I imagine you could check this bearing visually by loosening the pinch nut and pulling back the clamp and spring and using a mirror and flashlight to look up into the bottom of the tube. Maybe there is an easier way, but this certainly would have identified that my lower bearing was missing all the ball bearings, and my shaft had been eaten away.
Metalaroundstone is offline   Reply With Quote
Old 05-24-2015, 11:52 AM   #9
Wrenchbender Ret
Often the lower brg. gets stuck to the shaft. It needs to float to allow the spring to take up the slack.
Wrenchbender Ret is offline   Reply With Quote
Old 05-27-2015, 08:53 PM   #10
wilbur46
wilbur46's Avatar
Hey,
Stock steering columns will drive you nuts.
There are 3 eras, 60-62,63,64-66.
Then there are 4spd, 3 on tree, powerglide and hydromatic versions.
The 60-66 assembly manual is you only hope for a clear understanding of all the pieces in there correct order.
The illustration posted is (unfortunately) not of a 63 column, it is a 67-72 no tilt.
Both my 65s are jimmyed together right now too.
The parts sellers have no idea what you need.
If your 63 has a sheet metal can for the turn signal assembly, be sure it has twisted/ locked into the mast jacket slots before putting the turn signal assembly in and twist it to the right as you tighten the screws.
Sorry about no pics, but I am trying to find one example of everything and I'm gonna do a FAQ (or whatever)
Meanwhile------
wilbur46 is offline   Reply With Quote
Old 11-03-2017, 04:54 PM   #11
63 Burb
I’ve tried holding turn signal can in place while tightening.
There are 3 slots for can, one of mine is broken off, other than replacing whole column, I don’t know if there’s a fix?
63 Burb is offline   Reply With Quote
Old 11-05-2017, 04:07 PM   #12
rvrfoot
Any movement in the wheel from side to side is the upper bearing.
rvrfoot is offline   Reply With Quote
Old 11-07-2017, 09:09 AM   #13
63 Burb
Old 11-07-2017, 09:17 AM   #14
63 Burb
I’ve changed that bearing, all tight when assembled.
This model is a 3 on the tree, when you shift, the turn signal section rotates down and and comes off tabs that hold it in place.
There are 3 tabs one is broken off.
Old 12-02-2021, 02:26 PM   #15
dmulally
Seems I'm not the first person to have this problem. I have changed the bearings and even machined a flat washer to hold it in all in place. With the nut done up tight I still get play.
Does anybody have a cheat code to fix the play? My C20 failed a roadworthy check on it.
dmulally is offline   Reply With Quote
Old 12-02-2021, 03:11 PM   #16
cwcarpenter98
cwcarpenter98's Avatar
Did you adjust the spring at the lower bearing? That should help with side to side or up and down play. If you're getting excessive rotational play when turning the wheel back and forth, it's most likely in the steering gear if you haven't done anything with that yet.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-02-2021, 05:28 PM   #17
dmulally
Thanks. I just ordered a new lower bearing and already have a reco' steering box. It is just at the steering wheel end. I can move it all directions about 1/4".
Any tips for changing the lower bearing replacement?
Old 12-02-2021, 09:57 PM   #18
cwcarpenter98
https://lugnutz65chevystepside.weebl...n-rebuild.html
I have not done one yet, but this should help you out
Christian Carpenter
Old 12-05-2021, 10:17 PM   #19
dmulally
Interesting! Thanks mate.
Old 12-05-2021, 10:38 PM   #20
cwcarpenter98
Happy to help!
Christian Carpenter
Old 12-07-2021, 04:52 PM   #21
forestb
forestb's Avatar
I was having the same problem I found that the plastic tube that was bolted to the back of my steering wheel was not being pushed far enough into the bearing in the turn signal switch. what I did to correct it was add a spacer in between the steering wheel and the plastic tube and that made it go in further. The plastic tube is like a round wedge that keeps the wheel centered in the bearing. After looking at the previously posted link I think I realized that I am missing a bushing that goes in between the turn signal switch and the bottom of the cup that houses the turn signal switch. I also tried installing a brass bushing in between the shaft and smaller housing that it goes into but that caused my horn be on all the time. Here is the link to the tread that I started on the subject.
http://67-72chevytrucks.com/vboard/s...teering+column
forestb is offline   Reply With Quote
Old 12-08-2021, 09:24 PM   #22
G8rN@te61
Mine has like 4" of play in the steering. I assumed it is the steering box. is there a way to see if its the column vs the box that is the issue?
G8rN@te61 is offline   Reply With Quote
Old 12-08-2021, 09:55 PM   #23
forestb
forestb's Avatar
The column should just be a solid rod. So unless the bolt is not tightened all the way down on the wheel I would guess it is not the column. Have you checked the rag joint? It could also be your steering linkage and bushings. I would check all those things first before I look into the steering box. But in my experience it is usually the steering box.
Old 12-08-2021, 09:58 PM   #24
G8rN@te61
I saw mention of bearings in the columns so it made me wonder. I suppose I need someone to turn wheel and see how much the column moves vs the steering linkage?
Old 12-08-2021, 10:03 PM   #25
cwcarpenter98
If you don't have someone to turn the wheel for you, and you don't have fresh paint on the steering shaft, some vice grips clamped down will allow you to turn it from underneath the fender.
Also check to see if your frame is cracked around the box. That can cause a feeling of looseness. I need to fix the cracks I found recently....
Christian Carpenter
