What's wrong with this picture?
The gear indicator pointer just slides in but doesn't lock in, am I missing some type of retaining clip or something to hold it in place?
Moderator
![]() Join Date: May 2007
Re: What's wrong with this picture?
The groove on the bottom fits under the lens in the housing. You need to remove the housing to install the pointer.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Not sure I follow, are you talking about removing the (red arrow) housing or the (green arrow) housing? Please say green arrow!
Moderator
Two screws remove the housing that the lens sits in. The one with the green arrow in your pic.
Thank you ,Thank you, Thank you! I was starting to panic!
Look at the back of the P R N D D1 there is a slot between the column and the housing, the notch in the indicator travels in the slot.
And you might want to keep a spare, they will break if you look at the indicator wrong
Scott |
Thanks for the great pics Notsolo!
I see what you mean Scott, looks like a poor design. |
