Old 04-20-2015, 11:38 AM   #1
jrpitdog
REZ and CPP adapter plate question
I am going to be doing a power steering conversion on my 66 2wd c10 soon. I read somewhere maybe even a different board that the REZ and CPP plates had different width of spacers. Can anybody verify this? What is the correct width away from the frame the steering box needs to be? I don't want to get one that causes undo stress. Thanks.
jrpitdog is offline   Reply With Quote
Old 04-20-2015, 12:33 PM   #2
61K10
61K10's Avatar
Re: REZ and CPP adapter plate question
get one from Captainfab here on this site. he is a vender and his comes with a templet.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-20-2015, 02:57 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
110% agree with this!!! Captinfab's plate is SO much better and it doesn't require you to drill out the threads in the lower mounting boss on the steering box.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-20-2015, 03:19 PM   #4
jrpitdog
The thing is I have a chance to get a plate for basically free, just the work to get it off the wrecked truck. I don't know who made it but it looks of decent quality. If anybody knows I was simply wondering what the width is from frame to steering box mounting surface. If this plate is not correct I don't want to use it.
Old 04-20-2015, 03:35 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I agree, however I purchased mine around 25 years ago from REZ and it has held up very well and was what I needed at the time. Get it since it is free, then show some pix, that way Captn can als give his $.02
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-20-2015, 04:36 PM   #6
61K10
61K10's Avatar
if it's free grab it--worked on the other tk-------
1961 chevy K10
Old 04-20-2015, 05:59 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I'm running an REZ plate on my 1960 GMC. The plate is 1/8" thick, and the upper rear spacer is 1/2", so the space between the frame and the steering box is 5/8" at the upper rear mount as shown. This is looking straight down from above, as I have no inner fenders:
I would have photographed it with a ruler in place but I didn't have a third hand available.
One downside of the REZ design (and perhaps others) being one of the holes in the steering box requires drilling the threads out. If you keep the truck long enough to wear out the box and need a replacement, the original is ruined and cannot be turned in for the core charge because of the drilled threads. I put mine in over 20 years ago when it was the only thing on the market, so my options were somewhat limited!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-20-2015, 10:03 PM   #8
jrpitdog
Thanks that's what I was wondering. Also, is the spacing the same for all four holes?
Old 04-20-2015, 10:56 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
I can only see two more spacers easily, and they "appear" to be the same length. I don't have any practical way to measure them as there are too many things in the way. You may also find interest in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=346034
Old 04-20-2015, 11:17 PM   #10
AcampoDave
AcampoDave's Avatar
REZ plates were originally red and CCP's are black if that helps you I.d. what you may have
AcampoDave is offline   Reply With Quote
Old 04-20-2015, 11:27 PM   #11
oldies1938
DITTO.....I went with Capitanfab's
oldies1938 is offline   Reply With Quote
Old 04-21-2015, 12:41 AM   #12
Captainfab
60-66 Nut
All four of the mounting bosses on the steering box are on the same plane. My adapter plates space the steering box bosses out 9/16" from the frame. You might want to get the steering box also since it will be already drilled out for the CPP or REZ adapter plate.
Thanks for the recommendation guys
