manual transmission crossmember?
Ok. I am new to the chevy world. Even newer to the older trucks.
I bought a 1970 c10 and have found/replaced a bunch of parts including the transmission. I pulled the three speed and swapped it for a four speed. There was no crossmember for the rear of the trans when i pulled the three speed. Now the four speed "floats". Its only held up by the 4 bolts on the bell housing. I wanna say the trans is a borg warner t10 Does anyone know what crossmember fits? Or what after market crossmember i should buy? Thanks in advance. Last edited by foresterxtguy; 04-20-2015 at 12:17 PM. |
![]() Join Date: Dec 2012
Re: manual transmission crossmember?
if it is the SM465 4 speed, I think that's it. Just the cast iron bell housing with mounts and the tranny hanging off the back side.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I believe the Trans is a borg warner t10.
Edited above |
I have heard of guys just using the stock bell housing x-member but I don't think I would do it. The SM465 would prolly be OK but if you ever get on it with the T10 I would be afraid to crack the case with the added length. I put a Saginaw in my 72 Blazer and fabricated my own x-member but several outfits sell the. I think an automatic member will work fine and I think carries the same mount.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I just ran a 1/4" piece of flat bar across and bolted it to the frame and trany
Works great and cost me $5 at the scrap yard.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Yeah I used a 1/2" x 3 1/2" flat bar drilled w/tranny mount installed...
