08-30-2003, 08:09 PM | #1 |
triangulated ride tech 4 link?
anyone have their triangulated 4link setup? if so got any pics?
08-30-2003, 08:35 PM | #2 |
i don't think tri 4's are good for these trucks b/c of how close the frame rails are together. parralle would probly be a better way to go.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
08-30-2003, 11:22 PM | #3 | |
Under construction!
Yep! Roughly 33" from outside-to-outside. A parallel 4-link is visually easier to install but does require a panhard bar. That's not a big deal though.
2001 Silverado bagged on 22's. *Sold* |
08-31-2003, 02:17 AM | #4 |
Project92 SWB stepside
I have started on a rear tri 4 link. It is in the suspension section under Bolting up 4 link. There are a few pics there. Though it is not from the mentioned company.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
08-31-2003, 09:14 AM | #5 |
Happy to be here
I wouldn't suggest it at all. From what I know, Air Ride doesn't either "anymore". They did offer the kit for 73-87 trucks at one time. I have one on my 82 Blazer, and my buddy n2billet put one one his 84 SWB.
It just doesn't work well because the top bars aren't long enough, and it doesn't control side to side movement like it should. Yoo will be much happier with their parallel 4 link system....
08-31-2003, 09:15 AM | #6 |
Happy to be here
Here it is an n2billet's truck...
08-31-2003, 09:17 AM | #7 |
Happy to be here
One more...
08-31-2003, 10:12 AM | #8 |
thanks for the info, ill definately have to go with the parallel setupd then.
08-31-2003, 11:16 AM | #9 |
Trucker.
I had the parallel art link on the 83 and it was cake to install.
09-02-2003, 08:29 PM | #10 |
Couldnt he take and put a panhard bar on that and regain control of the rearend?? From looking at my tri 4 link do you think I will have the same problems
?? My top bars come on from the top at the mounting point for the side leaf spring brackets. Also mine appear to be longer. Why would longer be better. One would assume the shorter it is the less sway it would get??
09-02-2003, 09:43 PM | #11 | |
Happy to be here
Your bars should work better, for traction perpposes, because they are longer. Since they are mounted at more of an angle, they "might" prevent lateral play too. After playing with a couple of the triangulated 4 links we have come to the conclusion (and so has Air Ride) that a traditional 4 link with a panhard bar is the best route to take. It just creates more headache when it come to exhaust... |
09-02-2003, 09:59 PM | #12 |
Why didnt someone bring this up before??? This is just my luck. If I do have problems I guess I will add a panhard bar!! My exhaust will exit in front of the tire so thats not a issue. I see that my top bars come in at a reverse angle compared to your friends there. Mine seems to be real sturdy but I guess that is yet to be tested. What are your plans for the Blazer knowing this. How about you buddy??
09-02-2003, 10:32 PM | #13 |
Happy to be here
N2Billet plans to re-do his top bars, and go with a panhard bar, and traditional top bars.
The Blazer is a whole 'nuther story. Keith (n2billet) and I had a lot of conversation about it this past weekend. We need to take lots of measurements to determine what our next step is. I sold the 18/20's that I had on it. I am going for a bit bigger tire and wheel now, so we have to determine how much we have to change the suspension to get where we want to be. For some reason my Blazer rearend didn't seem to walk around as much as his trucks did. Here it is... |
09-02-2003, 10:32 PM | #14 |
Happy to be here
Another view...
09-03-2003, 02:28 PM | #15 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-03-2003, 05:08 PM | #16 |
You get what you pay for
Do I hear the kettle calling the pot black??
Mike 1985 Chevy C-10 |
09-03-2003, 07:32 PM | #17 | |
Happy to be here
09-04-2003, 12:57 PM | #18 |
I dont even want to know why your ass is that red And why are you posting smilies from fordpower.net?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
09-04-2003, 01:56 PM | #19 | |
09-04-2003, 04:50 PM | #20 | |
Happy to be here
Actually I have a buddy that has on 02 Mach 1 Mustang that hangs out there.... |
09-04-2003, 06:15 PM | #21 | |
09-04-2003, 07:17 PM | #22 |
driving is in my blood
And your one to talk from what I've heard mike....
You guys think hes bad, wait till my super cool smiles from a honda web site start getting posted
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-04-2003, 08:54 PM | #23 |
Nice looking atleast!! What is the best way to set this up as far as the pinion and all?? What angle did you use??
09-04-2003, 10:43 PM | #24 | |
Happy to be here
That really is the reason I go to that sight though. The Ford sight I frequent (and serve as a moderator) is specific to my truck. It is www.nhtoc.com. Heres a pic of my truck....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-04-2003 at 10:55 PM. |
09-04-2003, 10:58 PM | #25 | |
Happy to be here
It will look much better when we get everything painted and powder coated.... |
