04-20-2015, 06:03 PM | #1 |
Transmission problem
I have a 82 gmc swb and haven't had a problem with it but recently I had it parked for 2 weeks and now it's having trouble getting in the garage. Even going over curbs it seems like it doesn't have enough power but in a lower gear I have no problem.
Posted via Mobile Device |
04-21-2015, 10:33 AM | #2 |
Re: Transmission problem
What transmission do you have? Did you check fluid level?
04-21-2015, 12:43 PM | #3 |
I believe it has a 350 transmission and yes I have checked the level but may have a leak somewhere ? I drove the truck 7 hours when I bought it no issues .
04-21-2015, 12:58 PM | #4 |
You can count the pan bolts and look at the shape of the pan to determine the transmission type.
After that you will have to look at the adjustments for tv cable, take off pan and check fluid and filter condition, Check for vacuum line leaks if TH350 with a modulator and take a line pressure test. These should help to determine if the transmission is damaged internally. |
04-21-2015, 01:48 PM | #5 |
Trans pan shapes:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
