Old 04-20-2015, 06:15 PM   #1
OregonNed
OregonNed's Avatar
Wood bed installation
I haven't made any careful measurements yet of my existing truck bed, but has anyone replaced theirs using board dimensions different that what came with the truck? I'm just wondering if cross rails can simply be drilled for the difference or if anything else might keep this idea from being simple.
I have some great looking wood, but I am having difficulty coming up with enough boards to meet the 7 7/16 measurement for my wider boards. My thought is to forget about the 5 5/16 (I think that's it) boards and go with something narrower than the existing wides, and more uniform across the bed.
My truck is a '68 long fleet side.
Thanks!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-20-2015, 07:53 PM   #2
jeffahart
jeffahart's Avatar
Re: Wood bed installation
Are you wanting to use the wood because it's super nice, or because it's nice enough and you want to save money. I would rip one and biscuit joint it with exterior glue, gorilla or TB. Once it's bolted in and pegged down it will probably last quite awhile.
White K20
jeffahart is offline   Reply With Quote
Old 04-20-2015, 08:36 PM   #3
midniteblues
midniteblues's Avatar
you could use just about any width board with some drilling.
but if your useing oe/aftermarket bed strips then you could up useing more or less of them.
also if your going this rout to remember that the wheel tubs have bolts that go through also you dont want them too fall on a seem.
i'm likeing the trex material lots of guys been useing.
personaly i wouldnt glue/seem boards together if the truck is gonna be out in the weather much but thats my opinion.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-20-2015, 08:59 PM   #4
jeffahart
jeffahart's Avatar
Of course do what makes you comfortable and gives you the look you want. But you can glue and it will be fine. And if you use biscuits just saturate them good with glue and they will be stable once set. And, never let anyone talk you out of using anything but wood glue on wood. TitebondII will give superior strength over epoxy. Gluing and clamping is a way of life!
White K20
Old 04-20-2015, 11:41 PM   #5
kodiakjoey
Just lay your boards out the way you want them.Cut some groves for the strips and drill your cross rails.Name:  20150413_163758.jpg
kodiakjoey is offline   Reply With Quote
Old 04-21-2015, 10:40 AM   #6
OregonNed
OregonNed's Avatar
Thanks guys - I figured it could be done, but nice to hear some confirmation... Just wasn't sure if there were more factors involved underneath, other than the cross rails.
What I have is a fancy grade of flame / quilted Oregon myrtle wood that was cut and milled in Oregon - and I got it for literally a song.. Ten, 10-foot boards not quite 8 inches wide, over an inch think that required some major planing... The cost was about a fourth of what I have seen for most of the exotic woods..
Old 04-21-2015, 11:18 AM   #7
jeffahart
jeffahart's Avatar
Myrtle wood! Every time I'm out that way I stop, at I think Golds Beach, and get myself another myrtle wood bowl. I used to park my RV at Hiouchi Hamlet. And I always drive to Agness and jump in the river where the Rogue and Illinois join. I always eat nuts out of my Myrtle wood bowls, it's become a ritual over the years. How cool to have Myrtle bed wood. Please post a pic when you get it installed!
White K20
Old 04-21-2015, 11:52 PM   #8
OregonNed
OregonNed's Avatar
I certainly will
Old 04-22-2015, 10:50 AM   #9
OregonNed
OregonNed's Avatar
A couple of pics as the wood came off the planer....
Old 04-22-2015, 11:27 AM   #10
WarMonger
WarMonger's Avatar
Here is a question. Please excuse my ignorance. I have never had a wood bed, but have always though of this. Can you make the wood bed out of 1 piece and just router grooves for the metal strips to lay in?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 04-22-2015, 11:55 AM   #11
Lanman1972
Lanman1972's Avatar
I'm sure others will chime in, but I think it is designed to move with expansion and contraction of the wood during the seasons.
Lanman1972 is offline   Reply With Quote
Old 04-22-2015, 12:14 PM   #12
Davidf
Originally Posted by kodiakjoey View Post
Just lay your boards out the way you want them.Cut some groves for the strips and drill your cross rails.Attachment 1393653
Attachment 1393654
narrow groove as indicated in photos above does not allow the boards to contract and expand with varying temperatures. The grooves/dado's in the wood should be 3/16" wide and 5/32" deep. The wood thickness between edge of board and groove/dado should be 1/16" above bottom of groove/dado. Groove is 9/16" from edge of board (to far edge of groove). Hope that makes sense. This way, the boards can move around as they need to. I used Ipe for the bed wood on my '52. Ipe is also commonly referred to as "Iron Wood". It sinks in water, and virtually impervious to rot. Will last 50+ years untreated. Atlantic City used it for their famous boardwalk. It is commonly used as a decking material.
Davidf is offline   Reply With Quote
Old 04-22-2015, 01:16 PM   #13
zamboni2354
oh, that's nice!!
jeff in long beach
zamboni2354 is offline   Reply With Quote
Old 05-01-2016, 11:41 AM   #14
OregonNed
OregonNed's Avatar
I've made enough progress on this project that I think it's time to add some update pictures. We opted not to use the myrtle because it was not properly dried and suffered some warping. Instead we got ahold of quarter sawn red oak locally and my friend has milled, stained, drilled and sanded each board using my old bed wood as a template. I apologize in advance as some of these photos have been shared
In another one or two threads. Here goes
Old 05-01-2016, 11:46 AM   #15
35boulder
35boulder's Avatar
That myrtle wood is beautiful. Good luck with the installation.
35boulder is offline   Reply With Quote
Old 05-01-2016, 11:49 AM   #16
OregonNed
OregonNed's Avatar
Here are a couple of before pictures of the old bed. It was pretty sound but some of the boards we cracked and warped a bit.
Old 05-01-2016, 11:54 AM   #17
OregonNed
OregonNed's Avatar
My friend Ron cut the boards to size and milled them all. Here is the set he cut and milled
Old 05-01-2016, 11:56 AM   #18
OregonNed
OregonNed's Avatar
While he did this, I polished up the metal bed strips to reuse
Old 05-01-2016, 12:00 PM   #19
69short
69short's Avatar
That looks great! Can't wait to see more progress pics
69short is offline   Reply With Quote
Old 05-01-2016, 12:00 PM   #20
OregonNed
OregonNed's Avatar
I also took the opportunity to have the cross sills and some other parts sandblasted while the truck is parked. I painted each cross sill with POR 15, and top coat.
Old 05-01-2016, 12:06 PM   #21
OregonNed
OregonNed's Avatar
Sanding and staining will be finished today. He used a mixture of two anylin dyes to create the reddish look. With the weather warming he will begin 10 or so coats of Epiphanes clear marine varnish.
Old 05-01-2016, 12:07 PM   #22
OregonNed
OregonNed's Avatar
Yes, thank you! I will absolutely post more as we go...
Old 05-01-2016, 03:39 PM   #23
OregonNed
OregonNed's Avatar
First coat of finish down
Old 05-01-2016, 07:23 PM   #24
flintnoid
flintnoid's Avatar
deluxe oak kit from brothers trucks.. comes with perfect cut boards ..and all hardware also polished strips
flintnoid is offline   Reply With Quote
Old 05-01-2016, 08:00 PM   #25
flintnoid
flintnoid's Avatar
