Which leaves do I take out?
trying to lower my 1948 3100 Chevy pickup. On the rear, which leaves do y'all recommend to remove? i'm looking to gain a couple inches lower.
Re: Which leaves do I take out?
not sure how much you can lower a truck just by removing leaves.
i did remove the 2 short springs on my 58 to soften the ride isn't the axle above the springs on a 48 3100? if so use lowering blocks you may need to c-notch the frame at the same time
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
