I made bubble flares!
Big thanks to everyone that encouraged me to keep flaring and especially to the member that suggested I flip the flaring vise over. I can now bubble flare and I have 1 piece of my fuel line done. I managed to get it installed into the cab! *I had to cut out the rubber grommet to get the space to push it through but I think they made new ones of those.
![]() This piece of fuel line is not yet bubble flared on the top end (but it is now). ![]() |
![]() Join Date: Jun 2014
Re: I made bubble flares!
Nice job. Who makes that flaring tool?
Thanks. That's a Craftsman set. I am using Poly Armor tubing from NAPA. *My new piece shown here is about an inch taller than the old one but I'm going to put a fuel cut off valve in the center of it so if it's too tall I can shorten it then.
I knew you could do it
![]() i learned to make the bubbles by accident ![]() i'm not sure how your running your exhaust but on mine the exhaust is gonna run through the c-member. the rubber(flex line) between cab and frame just came too close for comfort too the exhaust so when i did the line(the rear part along the frame) i made sure i had metal line above the exhaust. just sayin cause the line from the tank too the rubber part too the frame(the one your making) could be made this way alot easier. oh an those rubber grommets can be a bear but usually a lil' lube helps big time....think ky ![]()
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Thanks man and I must say that I feel very good right now. When I bubble flared both ends of the in-cab line I literally stood there, holding the tube in my hands, and just staring at it.
![]() There seems to be some confusion concerning the lines though.....I am essentially going back with what was there before: metal lines connected by short lengths of rubber tubing and metal tubing with fittings for under the hood. The only changes I intend are 3/8" tubing vs. 5/16", a fuel filter located under the passenger side of the cab, and a fuel shut-off valve behind the seat. |
BlahBlahBlah
Good job, bending and flaring your own tubing is a real art form.
![]() Join Date: Mar 2014
awesome work. I do the same thing, just stare at it for a few minutes, then my son asks me, you ok?
