Old 04-20-2015, 10:20 PM   #1
Chrispbrown36
Name that part...
On my 350 TBI on the drivers side toward the rear of the valve cover (the oil filler cap is toward the front) there was a tube that came out and ran up near the throttle body....what is that part called? I say was because when I pulled the valve covers off it was split and just fell off. I was thinking I had read that it could be replaced with an oil breather, but I can't seem to find anything now about it.
Chrispbrown36 is offline   Reply With Quote
Old 04-20-2015, 10:40 PM   #2
Wrecked1982
Wrecked1982's Avatar
Re: Name that part...
from your description it should be the breather tube that goes to the air cleaner
1981 c30 dually, 350 sm465 ex tow truck now yard mule
1985 k35 dually, 454 th400 np205
1985 D30 cucv M1008, 6.2 th400 np208
1999 toyota tacoma, lifted 6'' 31'' tires
2003 toyota echo, reliable and damn cheap on ga
z
Wrecked1982 is offline   Reply With Quote
Old 04-20-2015, 11:05 PM   #3
Chrispbrown36
Ya, after I posted this I did some searching outside of this site and found what I was looking for. It appears I can use a button style breather that has a vacuum nipple and run a hose back to the throttle body collar.
