spring for drum brakes
Anyone know where I can get this spring and the piece that holds it on? I removed my rear drum and saw this mess. When installing I realized the two were missing and can't seem to find them online. I tossed my front drums a few weeks ago when converting to disc or I would have pulled it from there.
Re: spring for drum brakes
Anyone swapping to disc that might be able to help me out? I'd imagine the front pieces are the same.
Posted via Mobile Device |
You may need to buy a "Hardware kit" to get one. If you have a REAL parts store in town, not a "McParts" store but a real one they may have them in stock. It's amazing how long stuff stayed the same and they often have even old car and truck stuff in stock, at least the one I go to here in town.
And for that matter, just about any spring from a hardware kit for anything up through the seventies should work, even though the spring may look different. What they look like is a nail with a flatened end instead of a point. That goes through the backing plate and then a spring that has a washer like thing with a slot for a hole in it. You push the spring over it and rotate for the washer slot to go crossways over the head of the "nail" and there you have it. Here you go, a kit for $5 but you can probably get one at your parts store. http://www.fixthatferguson.com/index...19f59ac4bd82e5 ![]() Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Thanks! I looked into those and the spring might work, but they switched from the thick pins to those thin ones at some time. I have a Napa, but not any older parts places that I know of.
#5 | |
Brian
J hook and hold down springs. https://chevsofthe40s.com/dept/Brakes/cat/Hardware.html
At least that should tell you what the parts look like. Used they have to be off a truck or car with Huck brakes.
