Old 04-21-2015, 12:37 AM   #1
In The Ten Ring
Will a '67 to '68 steering wheel fit a '72 truck?
My original steering wheel is really breaking apart. I know nice OEM or NOS is hard to come by. Will a 1967 to 1968 steering wheel fit a 1972?
The '67 and '68's are all metal right?
In The Ten Ring is offline   Reply With Quote
Old 04-21-2015, 12:45 AM   #2
kcsa75
kcsa75's Avatar
Re: Will a '67 to '68 steering wheel fit a '72 truck?
Yes
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-21-2015, 01:05 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Of course
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-21-2015, 01:06 AM   #4
leddzepp
Moderator
leddzepp's Avatar
The compound used is much more durable than the 69-72 wheels and less prone to cracking.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-21-2015, 01:17 AM   #5
Gimme Jimmy
The older steering wheels were built over a steel bar frame but were overmolded with a material like hard rubber and painted. The paint would wear through in high wear areas. The newer ('71 and '72) were produced in a similar fashion using a harder colored plastic that was not painted, but was prone to deteriorate and crack, probably from UV exposure.
I believe they will physically interchange. The older wheels appear to be more durable.
Gimme Jimmy is offline   Reply With Quote
Old 04-21-2015, 07:23 AM   #6
7tee
7tee's Avatar
Oh yes, you'll be fine...
7tee is offline   Reply With Quote
Old 04-21-2015, 07:42 AM   #7
hugger6933
The wheels are still splined the same as they were as far back as I can trace. Back to the early 60's for sure. They just are useable as they went to a square center for the air bag in like 95[for the trucks anyway]. Jim
hugger6933 is offline   Reply With Quote
Old 04-21-2015, 09:59 AM   #8
Indyuke
Yes, and I think the older wheels look better anyway. This is on my 1970.
Indyuke is offline   Reply With Quote
