04-21-2015, 08:34 AM | #1 |
Ignition module
Which hei module's are you guys using and what not to buy...thanks
My motor is 1975 350... |
04-21-2015, 12:04 PM | #2 |
Re: Ignition module
I just buy the cheap ones from O'Reillys. But, buy two.
"Life is too short to drive a boring vehicle". Later, Wayne |
04-21-2015, 12:26 PM | #3 |
Re: Ignition module
I used a Proform brand. It's actually what's in the GM performance parts distributors. I'm not running at high rpm so there's no need for a more expensive one.
04-21-2015, 12:32 PM | #4 |
Re: Ignition module
Are they the same for V8 and inline 6?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
04-21-2015, 12:35 PM | #5 |
Re: Ignition module
Does anyone have a how to write up on replacing the module?
04-21-2015, 12:49 PM | #6 |
Re: Ignition module
Take the cape off. Take the rotor off. Take wires off module, remove module, put new one on with wires in the same place. Put rotor and cap back on. Takes less than 10 minutes.
04-21-2015, 01:38 PM | #7 |
Re: Ignition module
I have read that the NAPA ones and the GM ones are the best and to stay away from the generic ones from the discount stores. When you replace it, do use the little pack of dielectric grease the give you or you will be doing it again soon.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-21-2015, 02:14 PM | #8 |
Re: Ignition module
The reason I ask is this is my second new one in 3 weeks. While trying to chase down a "fish bite feeling" miss when at cruising speed I changed the module with a BWD CBE4 from Advance. It somewhat helped or maybe not but it did get worse to the point that the motor would just stop dead. After rolling to a stop it fired right up. Well after this happened the third time I put my old back in and it never died on me and the miss was still there. So I took the BWD back and they gave me another one. After installing the new module it still didn't fix the miss totally. Everything I can think of has been changed or rebuilt including carb. Maybe these BWD CBE4 modules aren't that good and I need GM, I don't know, but I'm tired...
04-22-2015, 06:59 AM | #9 |
Re: Ignition module
Has anyone tried a Wells module (DR100) made in the USA???
04-22-2015, 11:16 AM | #10 |
Re: Ignition module
Its not likely a bad module will cause a miss.
04-22-2015, 12:22 PM | #11 |
Re: Ignition module
Modules aren't really something that you can tell a difference with driving under 4k RPM. They either work, or they don't. If you're burning up modules, you should look elsewhere for your problem, or make sure you buy a quality one with a good warranty. Best of luck tracking down your issue!
04-22-2015, 12:26 PM | #12 |
Re: Ignition module
You are way over thinking this. Modules either work or don't work.
Yes, there are modules that are for performance use, that are for extended RPMs. But really, an HEI module is an HEI module. Just be sure to use the supplied grease/compound when installing the module.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-22-2015, 12:28 PM | #13 |
Re: Ignition module
Yes, that is a standard 4 pin module, super typical module.
04-22-2015, 02:33 PM | #14 |
Re: Ignition module
To all that say that modules either work or they don't, no offense but, I have seen 2 intermittent GM modules, 1 Accel, and one cheapie. They'd work fine until they quit.
The weirdest one was the Accel module. The car was hard start. Sometimes had to crank 5-10 seconds then the tach would jump and the car would start. I drove it that way for 2 weeks until I opened the hood and changed it. For some silly reason I kept it for a spare. No further problems with it until I put it in the truck one day to troubleshoot a miss. It worked well enough to let me drive around the block then it failed in the street in front of the house. Have you ever tried to push a Longhorn up a slanted drive by yourself? Another note: clean the OLD grease off the base of the mounting surface prior to applying the new dielectric grease. Inspect the condenser, and the plugs that mate to the module.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-22-2015, 02:35 PM | #15 |
Re: Ignition module
Thanks for all the responses and maybe I'll look at this 600 holley again even though it's been rebuilt...
04-22-2015, 02:47 PM | #16 |
Re: Ignition module
ive learned ( but everyone has different lessons theyve learned ) to stick with gm modules. they just seem to last longer,
1967custom |
04-22-2015, 03:44 PM | #17 |
Re: Ignition module
ditto on the dielectric grease, you'll fry that puppy in five minutes or less.
Ben |
04-22-2015, 03:48 PM | #18 | |
Re: Ignition module
Be sure to read this... Best thing you can do is read this book. Every bathroom needs one of these books. LOL! http://www.summitracing.com/parts/hpb-hp473
