Old 04-21-2015, 08:57 AM   #1
WEBBY1
WEBBY1's Avatar
radiator replacement
What radiators are you guys running? Looking to order one today.. Was thinking about a champion with an electric fan. I will be running a 355/4l60 combo.
WEBBY1 is offline   Reply With Quote
Old 04-21-2015, 10:26 AM   #2
Mackie
Mackie's Avatar
Re: radiator replacement
I used a Champion from an eBay vendor. Great price and plug `n play fit. Integrated oil cooler but I left them plugged cuz I run a T5.
Mackie is offline   Reply With Quote
Old 04-21-2015, 04:25 PM   #3
forestb
forestb's Avatar
I put a us radiator in mine and it bolted in perfect. Have not started truck after install.
forestb is offline   Reply With Quote
Old 04-21-2015, 04:58 PM   #4
1963c-10
1963c-10's Avatar
Champion here as well
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-21-2015, 07:45 PM   #5
LDO
LDO's Avatar
Not to hijack but which size did you go with? 3 or 4 core? I don't think the 4 cores will work without modifying the lower saddles??
LDO is online now   Reply With Quote
Old 04-21-2015, 09:02 PM   #6
Rhino198073
Also Bought the champion from eBay.
I will need to modify the saddles though.
Rhino198073 is offline   Reply With Quote
Old 04-21-2015, 09:35 PM   #7
Lugnutz65
Lugnutz65's Avatar
The OP question and replies made me remember the comments made in this post. I'm not saying Champion radiators are bad. I have an original Harrison radiator that I hope will perform well enough, but I think I'd go with a Griffin instead. It's good to have options.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-21-2015, 11:20 PM   #8
BigElittleg64
BigElittleg64's Avatar
Like the radiator with the side flanges forestb. I to am looking for a radiator. Called Champion and was told an EC284 will fit our trucks but I don't think it has the flanges on the side. I would have asked but i was at work at the time so I will have to call them back. Can any one confirm this or have a part number for a radiator with the side flanges.
BigElittleg64 is offline   Reply With Quote
Old 04-21-2015, 11:49 PM   #9
russellrox
what radiator combo's are you guys running with 5.3 and 4L60e
russellrox is offline   Reply With Quote
Old 04-22-2015, 06:33 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
It's good to know US Radiator has a nice unit for these trucks. I have used them in past hot rod builds.
Old 04-22-2015, 08:32 AM   #11
1963c-10
1963c-10's Avatar
Its a 3 core, been running it since 2009.
Old 04-23-2015, 09:52 AM   #12
AcampoDave
AcampoDave's Avatar
I made a search of this site in the past and found a lot of us like the one from engeneered cooling products. I bought one too. Great radiator, good price. Ordered it online at speedcooling.com I did have to modify the lower saddles and the top mount is a tight squeeze but other than that no problems, and 20 degrees cooler than before.
AcampoDave is offline   Reply With Quote
Old 05-20-2015, 11:41 AM   #13
Justin@EntropyRad
Justin@EntropyRad's Avatar
Would you mind sending me info of where you had to modify it to fit? We are always trying to improve things, so if we can make anything fit better..we are all for it!
Thanks much
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 05-20-2015, 12:05 PM   #14
brap999
brap999's Avatar
I run the Champion, with electric fan and shroud bought on ebay for the last 3 years, and its been awesome. Never have over heating problems, even on the hottest of days.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 05-20-2015, 03:51 PM   #15
thefaceman
thefaceman's Avatar
What temp is preferable for a 350?
66 C/10 LWB
http://i.imgur.com/EcqZpK7.jpg
thefaceman is offline   Reply With Quote
Old 05-20-2015, 08:24 PM   #16
AcampoDave
AcampoDave's Avatar
I like 180 +or- a few degress. 200 and up makes me nervous in my climate.
Old 05-20-2015, 09:18 PM   #17
dougf
dougf's Avatar
Lots and lots of opinions. Anywhere from 180-210 is what I find. Run my 327 at 195 for what it's worth.
dougf is offline   Reply With Quote
Old 05-21-2015, 08:12 AM   #18
verdell
verdell's Avatar
Griffin radiator and Lincoln Mark VIII electric fan...I like about 180 degrees
verdell is offline   Reply With Quote
Old 05-29-2015, 10:02 AM   #19
Justin@EntropyRad
Our premium setup: http://www.entropyrad.com/1963-1966-...-radiator.html
Our Driver setup: http://www.speedcooling.com/1963-196...r/prod_37.html
Justin Novick
(773) 303-8251
Sales/Support
Old 05-29-2015, 03:33 PM   #20
Uptown83
Originally Posted by Justin@EntropyRad View Post
Will painting them black effect the radiator any?
Uptown83 is offline   Reply With Quote
Old 05-29-2015, 03:34 PM   #21
Justin@EntropyRad
Not if you use the eastwood radiator paint..it is thin enough to go on there without affecting the cooling
Justin Novick
(773) 303-8251
Sales/Support
Old 05-30-2015, 08:58 AM   #22
Gooker928
85 corvette radiator with dodge intrepid fans. You will have to fab mounts.
Gooker928 is offline   Reply With Quote
Old 07-01-2015, 09:35 AM   #23
SparkyRnD
SparkyRnD's Avatar
we make made in the USA aluminum radiators, using domestically sourced materials. Each unit is TIG welded by hand, and we NEVER use epoxy or plastic in our rads. You can see feedback from customers on this forum, and ours are a direct fit and we never charge for building them to accommodate engine conversion (ie: no extra cost for LS ports, steam port, or built in trans cooler). We also offer a discount for forum members!!
http://67-72chevytrucks.com/vboard/s...d.php?t=591690
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
