Old 04-21-2015, 09:39 AM   #1
ArkGL01
Spare tire information help
I am working on a 72 cst blazer and it has original carpet and I don't see where a spare tire carrier was and there are no holes. Could you get one with out a spare? What were the options and what do I need to look for on it. Thanks for any help.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze.
ArkGL01 is offline   Reply With Quote
Old 04-21-2015, 09:49 AM   #2
1rippen6
Re: Spare tire information help
Inside spare tire carrier will be behind the back seat drivers side mounted to the floor. There should be 4 nuts on the bottom of the floor board if you look from the bottom. I can get you a picture tonight of the holes just don't have a spare tire carrier.
1rippen6 is offline   Reply With Quote
Old 04-21-2015, 10:28 AM   #3
Dirt's72
Curious if it has carpet over the wheel wells?
Dirt's72 is offline   Reply With Quote
Old 04-21-2015, 10:33 AM   #4
ls1nova71
ls1nova71's Avatar
This is true if it has a back seat, if it didn't originally have a back seat, the spare tire carrier will be directly behind the driver's seat. There should be nuts welded to the underside of the floor with little cage things over them to keep water out of them if there are no bolts in them.
If it's original it won't. Wheel wells were never carpeted from the factory.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-22-2015, 09:46 AM   #5
1rippen6
Red circles are where the spare tire mount will bolt down
Old 04-23-2015, 10:10 AM   #6
ArkGL01
I cant find any holes in the floor. It has carpet over the wheel wells. Think it would have been on the outside. It has been repainted so could have had holes filled.
Old 04-23-2015, 10:18 AM   #7
1rippen6
There sound be 4 large nuts weld to the floor board underneath can get pictures of that if you like.
Old 04-23-2015, 10:49 AM   #8
briank
May not have had one. My 1970 doesnt have one, the previous owner had a spare mounted on the front bumper and its never had work done to it. Mine never had a rear seat so mine would have been mounted behind the front drivers seat. You would think a factory cst would have had one though.
briank is offline   Reply With Quote
Old 04-23-2015, 11:06 AM   #9
smbrouss70
smbrouss70's Avatar
My Blazer came with a driver's seat only, no passenger's or rear seat. When they came like that from the factory they had a small bracket welded on the rear floor to hold the spare flat on the rear floor. Maybe you have one of those or the remnants of it. It's the thing in the red circle.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-23-2015, 11:13 AM   #10
ArkGL01
Was the tailgate one actually an option from chevy?
Old 04-23-2015, 01:01 PM   #11
briank
I think it was only an aftermarke item.
Old 04-23-2015, 02:42 PM   #12
1rippen6
They is a forum member selling the tailgate style if he has any left midunes he also restarted the Hickey brand.
Old 04-25-2015, 09:37 PM   #13
briank
Ok, I was mistaken in my earlier post about my 70 not having a mount. I crawled under it today and saw that it had the holes and welded nuts behind the drivers seat so it looks like they all came with the mount, even when ordered with one or two front seats.
