wheels with or without nubs or clips...
Unsure what style to send to powder coat...left ones with the clips and no nubs...or right ones without clips but with nubs...i have both complete sets....
![]() Join Date: Aug 2013
Re: wheels with or without nubs or clips...
are you gonna use hubcaps? if so which style do you have? and use those matching rims!!! if you have both cap it docent matter, if no caps either will look basically the same...
Caps are easier to find for the nub style.....in my opinion.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
ya im leaning tword the nub style
Senior Enthusiast
A couple other things to consider - the nub style are probably years newer than the clip style and may be in better condition. The nub style are "usually" welded together, while the clip style are frequently riveted together. This may or may not be a problem with future leakage. And lastly, the nub style may have "safety beads" pressed into the rim. I've never seen a clip style wheel with this feature. The safety bead is a depression in the rim that holds the tire on the rim if it goes flat. Early wheels have one bead on the front side. all newer wheels have safety beads on both the front and back of the rim.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
![]() Join Date: Aug 2010
As stated, the nub rims are easier to find caps for. If condition is the same, the hubcap factor should be enough to decide.
![]() Join Date: Aug 2008
disc or drums?
#9 | |
![]() Quote:
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
nubs it is then,..thanks guys...on another note...im still unsure of color..i did a quick edit on my phone with a few combo's...top is how it is now with the full caps, middle is black with small caps,..and bottom is red with small caps...thay all look good in my opinion,..whats your take on the color combo?
top
Senior Enthusiast
I like the top version best as well. I'm most curious about that unusual camper shell you have installed!
#13 |
#14 |
![]() Join Date: May 2007
full wheel cover
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#15 |
Moderator
![]() ![]() Join Date: Aug 2011
Top
