Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-21-2015, 01:08 PM   #1
tiddlar
Moser m9 purchase
Hey gentlemen, I just ordered a moser m9 housing with 35 spline axles. I'm getting a chassis built. The center section is $$$$ my question is can I get a center section from somewhere that's cheap to use as mock up? I want something cheap , I won't use it, just need it so the chassis can be on the ground. When budget permits I'll get what I need to get. Thanks guys
tiddlar is offline   Reply With Quote
Old 04-21-2015, 07:09 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Moser m9 purchase
for a 9" the bearing retainers will hold axles in place. A 35spline axle should slip into a piece of 1-1/2" roll bar tubing if you were worried about the weight on the axle bearings with nothing to align them. With no centersection you will be able to reach right in and slip the tube over both axles. (just put it on one when you install the axle)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-21-2015, 09:50 PM   #3
tiddlar
No idea what you said.. Sent it to my fabricator see what he says. Sounds like it could work.. I'm not very mechanically inclined... That's a talent... I just didn't budget myself for the center section.. Though axle and housing would get me a roller. Hey thank you for your input
Old 04-21-2015, 11:53 PM   #4
71Dragtruck
71Dragtruck's Avatar
He's saying you don't need the center to mock up the chassis, all you do is slide a piece of tubing over one axle, then install it with the tubing at the end (bearing installed on the axle of course) and then install the other axle on the other side sliding the tube so that both axles are now inside it and the tubing is in the center of the diff, now retain the axles with the retainer plates.
You can now mount wheels on it and put the weight of the chassis on it with no need for a center section untill you get the one you are going to use. To get a mock up center section to work you would need a 35 spline spool or diff of some sort to fit your axles, not worth the effort when you will likely be purchasing a complete built center when the time comes.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 04-21-2015, 11:57 PM   #5
tiddlar
Thank so much gentlemen. I highly appreciate your knowledge.
Old 04-22-2015, 01:26 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hehe anyone notice how trying to explain "shop logic" thru the internet never seems to translate the first time?
Its kinda like when I explain if "something fits"....well i mean heck, it fits, if it fits.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-22-2015, 06:29 AM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
35 spline will also require a big bearing center section . You could take a junk center and pull the carrier out and leave the caps off and bolt it in with said piece of tubing installed if needed .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-23-2015, 11:30 AM   #8
Marv D
Marv D's Avatar
ABSOLUTELY!! heck I'm lucky if my ramblings make sense after the 10th time I try to explain.
