Need help identifying where this part goes
1990 Suburban
I took the steering column apart to fix the sloppy tilt column issue. When I was taking it apart at around this step, this little spring clip fell out. Now I don't know where it goes. ![]()
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Here's another picture of the spring clip
. ![]() Posted via Mobile Device |
Re: Need help identifying where this part goes
is it the spring for the hazards to stay in place? here's a pic of mine, i don't think its missing from the front side of the turn signal assembly
![]() Last edited by Guilty-by-Design; 04-21-2015 at 06:46 PM. |
The plastic is missing and looks to be bent up on the one end, but that sure appears to be the key reminder switch. there is a square hole under the T/S switch near where the ignition cylinder that it fits into. the plastic portion might still be there, just no metal part.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
The plastic is missing and looks to be bent up on the one end, but that sure appears to be the key reminder switch. there is a square hole under the T/S switch near where the ignition cylinder is located, that it fits into.
![]() Join Date: Jun 2009
You are right on the money. That is exactly what it is.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
That is the right way. The copper tabs go at the top and point to the left when you are installing it.
