Old 04-21-2015, 05:21 PM   #1
pointer80
pointer80's Avatar
just got blazer home and it's leaking
Just got my blazer home from Arizona and it does have a couple of leaks behind the front seats. The good news is the floor is completely rust free under the carpet. The preveous owner put silicone on the seal between the cab and top instead of a new seal. Is this typical in a k5? Here are some pics. Thanks all.
pointer80 is offline   Reply With Quote
Old 04-21-2015, 09:39 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: just got blazer home and it's leaking
Eh, PO did that on my 79. Do you have any rust on the half cab?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-21-2015, 11:40 PM   #3
pointer80
pointer80's Avatar
where are you talking about on the half cab? I cannot see any rust anywhere on the body.
Old 04-22-2015, 09:10 AM   #4
68Timber
68Timber's Avatar
Where the fiberglass top bolts to the back of the cab, you mentioned the PO used silicone there.
John
74 Honda Z50 build
Old 04-22-2015, 11:54 AM   #5
pointer80
pointer80's Avatar
Oh ok, gotcha. No there is no rust. The po siliconed the outside of the cab/top moulding instead of replacing the seal and doing it right. I am assuming out in Arizona you can get away with that because they get so little rain.
Old 04-22-2015, 11:59 AM   #6
68Timber
68Timber's Avatar
10-4. Count yourself lucky, my 79 had silicone there too but has some rot on the mounting flange where the top bolts to the back of the cab. And of course all that sheetmetal is wavy, it'll be fun to replace.
John
74 Honda Z50 build
Old 05-11-2015, 11:13 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
When I got my 79,it had rubber goo wedged under the corners,prevented the top from dropping in right.
mine leaked at the light,so they sealed that across too.
fine now,if it rattles I don't hear it lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-28-2015, 10:50 PM   #8
'68 Newtricks
'68 Newtricks's Avatar
Replace both seals and be happy. Mine were rotted away but still sealed pretty good. I only noticed a small damp spot when I got in after it rained, but not while I was driving.
The soft top I have now, doesn't leak
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
