Old 04-21-2015, 11:14 PM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
Question regarding steel wheels..
So I went to the Portland swap meet and found what I thought was a 15x8 6x5.5
Steel wheel. We'll I should have measured it because it's 15x9 now I am pretty sure that's not a standard size please correct me if I am wrong. The ultimate desired outcome was 15x8's on the back and 15x6's up front. I found a 15x7 on craigslist for 10$ couldn't pass it up and now I am wondering if that's a standard size. If they are can anyone point me in a direction to help me make it 15x9 on back and 15x7 up front? Or do I need to just fin 8's and 6's?
This is the style wheel with my caps and withoutName:  image.jpg
They should look pretty cool with the impala caps. Oh and the offset on the 15x9 is 4"..
Thanks all
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 04-21-2015, 11:16 PM   #2
67chevy_hotrod
Re: Question regarding steel wheels..
Size:  77.1 KB this one didn't post
1967 Chevy CST 10
1969 K10 Suburban
Old 04-22-2015, 05:49 AM   #3
First you need to be sure to measure from inside bead to inside bead. I don't know about 7" or 9" steel factory wheels, just 6" and 8". I'll bet that wheel is 8".
Old 04-22-2015, 09:38 AM   #4
davischevy
davischevy's Avatar
Pretty common mistake to measure outside of rim instead of inside bead. special-K is right, measures to inside of bead.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-22-2015, 10:10 AM   #5
geezer#99
geezer#99's Avatar
Always measure to the outside and subtract one inch!
More accurate than trying to measure bead to bead.
Old 04-22-2015, 10:45 AM   #6
Keith Seymore
Keith Seymore's Avatar
I would suggest that measuring bead to bead is more direct, accurate enough for the application, avoids a spurious error from measuring a less controlled trim edge, and is pretty much universally accepted.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-22-2015, 10:55 AM   #7
geezer#99
geezer#99's Avatar
Give 10 people a tape measure and tell them to measure the width from rim edge to rim edge and all of them will get exactly the same measurement.
Get those same 10 people to measure the bead to bead and you'll get 10 different answers.
What are you gonna do when the tire is mounted?
Can't measure bead to bead but you can still measure rim edge to rim edge.
Old 04-22-2015, 11:02 AM   #8
EARNHARDT#3
EARNHARDT#3's Avatar
Who are these people and why can't they do it both ways?
You're going to have a difficult time either way with the tire mounted.
The end.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-22-2015, 11:16 AM   #9
michael bustamante
michael bustamante's Avatar
you guys are funny
op..... so what did you find out?
did you see any markings that maybe indicate aftermarket?
1967custom
michael bustamante is offline   Reply With Quote
Old 04-22-2015, 11:28 AM   #10
67chevy_hotrod
Thank you guys I told my old man I said I am almost positive it's inside the bead and he says no no no and the guy I got the 6er from measured it right in front of me and said seven and made me feel dumb lol thanks everyone
1967 Chevy CST 10
1969 K10 Suburban
Old 04-22-2015, 03:00 PM   #11
Willie Makeit
Willie Makeit's Avatar
some people shouldn't be allowed to use complicated equipment such as a tape measure.
anywhoo, it's inside to inside for folks that know. outside to outside for those that the rest of us point and laugh at.
Willie Makeit is offline   Reply With Quote
Old 04-22-2015, 03:23 PM   #12
geezer#99
geezer#99's Avatar
It's rim to rim minus 1 inch for those who know!!
Don't make me point and laugh again Willie!!
Old 04-22-2015, 04:31 PM   #13
Willie Makeit
the minus 1 inch portion of your equation is totally dependent upon the wheel itself. some wheels have smaller leading edge. some have a larger leading edge. your logic is flawed.
oh. i see you're from canada.
<snicker> <point>
Old 04-22-2015, 04:47 PM   #14
dubds10
Stalker Nate
All our rims in Canada are exactly 1" extra so we just measured edge to edge and subtract hahaha
*Not serious for those who actually think Canadians have weird stuff and live in Igloos
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 04-22-2015, 05:23 PM   #15
geezer#99
geezer#99's Avatar
<snicker> <point>
Still laughin' at you Willie!!
Maybe I shoulda used mm. Like in 25.4mm.
Gotta go feed my sled dogs and water the hamster (battery going dead). With no water he can't keep the wheel turning to make power.
Oh!! And turn on the northern lights too!!
Old 04-23-2015, 07:20 AM   #16
Keith Seymore
Originally Posted by michael bustamante View Post
you guys are funny
x2
Not to belabor the point, but since wheels are typically 6", 6.5", 7", 8", etc, ask those same people to round their answer to the nearest 1/2" and see what they all get.
K
1979-1986
1986 - 2019
Old 04-23-2015, 07:21 PM   #17
MikeyMan
<snicker> <point>
Depends on the exchange rate
MikeyMan is offline   Reply With Quote
Old 04-23-2015, 09:48 PM   #18
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Don't you mean edge to edge minus 2.54cm, eh?
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-23-2015, 10:12 PM   #19
davischevy
davischevy's Avatar
Bottom line is, the OP thought he has a 228.6 MM wheel, but after subtracting 25.4 MM, actually has a 203.2 MM wheel.
How the hell go we get so much mileage out of a simple subject like this. We obviously need a life.
Have a Great Day,
Larry
other Larry
Old 04-23-2015, 10:20 PM   #20
oldertruckfan
wow. speechless.
oldertruckfan is offline   Reply With Quote
Old 04-24-2015, 11:05 AM   #21
davischevy
davischevy's Avatar
Sorry forgot to add LOL.
other Larry
Old 04-24-2015, 11:25 AM   #22
lowrollin70gmc
Too many projects
And to address another of the OP's questions, I would run whatever sizes you can find given that they're matched pairs. If that means 6s/8s (15.24/20.32s), 7/9s, or 6/9s it shouldn't be a big deal. I would just test fit the wheels before mounting tires to eyeball that there is enough room and the backspacing is what you want. Our rear wheel wells are pretty roomy but the front fender edge can get close sometimes on a lowered truck.
Andrew
Old 04-24-2015, 11:31 AM   #23
GoaterAz
GoaterAz's Avatar
You don't want those.
Probably just sell them to me.
I'm too good to you.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 04-24-2015, 02:26 PM   #24
davischevy
davischevy's Avatar
I was thinking the same thing.
We had to call Arizona to get a set. I hope their in transit.
other Larry
Old 04-24-2015, 03:32 PM   #25
67chevemall
67chevemall's Avatar
I got if you need
1 15x8 6 lug
2 15x10 6 lug custom builds
1 15 x 7 6 lug
And Canada rules kids....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
