6.8 MPG ok?
My 86 c10 is running basically a cast iron head ZZ4 rebuilt 750 quadrajet elderbrock performer inlet with ceramic long tube headers and a stainless 2.5 inch mandrel bent dual exhaust/700R4/ford 9 inch with 3.50 gears.
Sitting between 70-100mph(GPS NOT SPEEDO) on a recent 60 mile run with hard 3rd gear acceleration between those speeds on flat freeway I am getting 6.8mpg does that sound about right? |
Re: 6.8 MPG ok?
what RPMs where you revving at? around town in 3rd gear i avg 10 in my lifted k10 w/ 35's. so depending on what your RPMs where that doesnt sound right.
1986 K1500 Pro-Street 4x4 |
Re: 6.8 MPG ok?
Hard acceleration and freeway speeds and faster in 3rd gear? 6.8mpg sounds about right to me. You're running it pretty hard, that's the mileage you can expect. I used to get between 5 and 10, same truck, same motor, same driver, now I get 12 consistent. The difference? I'm 15 years older
Re: 6.8 MPG ok?
What wheels are those? Also it does seem like you should be able to pull off 12-14mpg.
Re: 6.8 MPG ok?
Sounds about right there are rpm calculators your probably at those speeds between 3 and 4 grand not ideal for fuel mileage. The diff between running 65 and 75 is huge in fuel mileage at 80 plus it really tanks.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
driving is in my blood
Re: 6.8 MPG ok?
Sounds horrible. You don't say which heads, but it sounds like a 350 with small cam, performer intake w/ Qjet carb and exahust. With overdrive and 3.42 gears on the freeway you should be a minimum 10mpg. My 78 has always gotten 10mpg even with different engines, 3.73's and no overdrive and my 79 would hit 15mpg with a vortec 350 and 200-4R
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Re: 6.8 MPG ok?
10-12 on the highway travelling 55-65 no problem. 70-100mph with full throttle 3rd gear acceleration, 6 is totally possible, and expected, maybe worse.
Re: 6.8 MPG ok?
The motor has vortec heads it's a GM crate motor 330hp HO but for some reason the Australian version comes with a roller cam which sort of makes it a iron head ZZ4.
Wheels are 17 inch rally replica but no idea who makes them. I was pretty suprised how quickly the fuel needle was dropping but for short bursts I may have been hitting 110 as I was trying to keep a friend in sight who was not slowing as much in the corners. 6.8 seemed high to me as I usually get 9-10 on this run sitting on an even 85mph.I guess those extra 15mph and WOT burst's take there toll. 60 mph is 2100 rpm with this diff and wheel combination and it gets 14mpg-15mpg but rarely drive at that speed once I am out of the city limits. Last edited by ozkiwi; 04-22-2015 at 07:06 PM. |
#9 | |
![]() Quote:
Re: 6.8 MPG ok?
Re: 6.8 MPG ok?
yeah, i guess when you got 900 miles of wilderness between towns, you dont want no kmh's
![]() i wish we would revert back to the "proper" way (mph) at them speeds, i think your mileage is pretty good. i cant even get that with a egg under the throttle, & when i'm on it-half what your getting-glug, glug, glug! ![]() ![]() ![]() |
#12 | |
Re: 6.8 MPG ok?
That run was done during the week in between 2 country towns following a friend who is a truck driver and knows when and where it safe to speed out there. If we got caught by the cops it would be good by license for a year and $1000 fine. |
#13 |
Re: 6.8 MPG ok?
#14 |
Re: 6.8 MPG ok?
For your engine, your WAY over carbureting. For the displacement of your engine, even if its spinning all day at 7000 rpm you dont need more than a 600 cfm carburetor. Period. At 100% volumetric efficiency (formula 1 engines are around 96% VE) You would only need a 700 cfm carb. Thats why you have crummy mileage. I know bigger seems better, but you engine will only use so much fuel and pull so much air. Things quickly turn to crap when your carb is not matched to your engine. Trust me here, you need a smaller carb. You will even see an increase in performance and mileage.
#15 | |
Parts and more parts
Re: 6.8 MPG ok?
Just for instance, I have an 84 GMC SWB truck with a 383 stroker engine, 650 carb, 700R4 tranny, 3.73 gears and a 28" tall tire on my truck. I can average 15 MPG running down the highway at 75 MPH--running at 2700 RPM. This was with a tranny that did not have a lock-up converter. I just added a new converter and I now have the lock-up feature and I can move down the highway at a lot lower RPM and I will have to see what I get for mileage, this summer. The lock-up is worth 200 RPMs. Get a tire size, gear, RPM calculator out of the computer and start working to bring all of your components together and match them up and your mileage will grow.
Frank |
#16 |
Re: 6.8 MPG ok?
Ok I am confused now. The quadrajet is the factory fitted carb that was fitted to it's original 305 motor?????
So that must have been wayyyy over carbed? I have not changed the jets so seems odd that I am over carbed on a bigger motor making double the horsepower. Not saying I won't try a smaller carb just don't understand the factory 305 with this set up. |
#17 |
Re: 6.8 MPG ok?
Not all Q-Jets are 750cfm. Q-Jets were made from approximately 635cfm to 760cfm. unless you have a Q-Jet from a performance big block or the biggest was only in the GMC motorhome. The smallest were used on 6 cylinder engines. Yours would be most likely in the 650cfm range for a 305.
When you are running down the highway with a Q-jet and you are tipping into to secondaries you can count on fuel economy to go out the window. Many years ago I had a 67 GTO and did a WOT run on the freeway. I was doing a 20 mile race WOT with AX secondary rods and you could literally watch the fuel gauge go down. I remember burning almost a half a tank that night just on that run.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
#18 |
Re: 6.8 MPG ok?
When you're running down the highway at 70mph, racing up to 100 you're getting into the secondaries on any carb, not just a Q-Jet. The Q-Jet is fine, it's not where your fuel mileage is going. No carb will give you the driveability of a Q-Jet on the street.
You're pushing a 5,000 pound square steel box to 100mph and running it hard to get there. That's where your fuel mileage is going. Your right foot. No amount of carb tuning or swapping is going to get you better than what you're getting in those conditions. They're all just garden hoses dumping fuel at that point. |
#19 | |
Re: 6.8 MPG ok?
The thing is, your engine is only going to pull so much air/fuel at a given moment. A cylinder can only pull its volume in a single stroke *forced induction aside* So, running too large of a carb is in no way beneficial. Even if a 750cfm q-jet has been re-jetted to run on a smaller displacement engine, then its still going to over fuel the engine as its designed to run on an engine pulling more cfm than a 350ci can provide. This is why mass-air fuel injection systems give stellar power and fuel economy. Even with a 100mm throttle body, the fuel system reads how much air your engine is using, and adjusts the fuel to match. Lastly, Q-jets are a great carb when they are running right. But when they are in need of a rebuild, mileage goes right down the crapper. |
#20 | |
Re: 6.8 MPG ok?
A vacuum secondary carb is only going to allow as much air as the engine can use. A Q-jet's secondary fuel metering is keyed directly off the secondary air valve not the throttle plates. Assuming the carb is working as designed the air valve will only open as fast or as much as the engine can take. This is why the vacuum secondary carbs are more popular on the street. They by design are more forgiving to the matching of CFM to cyl. volume. our squares are big concrete blocks on wheels neither aerodynamic or light you could stick a Rochester 2GC on top of a 350 and the gas mileage is not going to improve much at all. why? because you foot will be in more to keep up with the Q-jet version doing the same thing.
#21 |
Re: 6.8 MPG ok?
The fact that my quadrajet is not a 750 makes much more sense.I cannot even remember why I thought it was.
How do I identify what size carb I have? I bought a rebuilt carb from summit racing so the old one is just sitting in my workshop.I will have a good look at it tomorrow once I know what to look for I am very happy with the performance of the motor and fuel mileage in general I was just surprised at the difference between fuel use at steady 75mph and big increase when you give it a bit. I have never owned a vehicle running a carbed V8 before this truck. I have been driving modern small fuel injected pickups that I have just been A to B transport but I love driving this old truck and have developed a bad habit of driving it quiet hard since the new motor went in. Last edited by ozkiwi; 04-25-2015 at 07:03 PM. |
#22 |
Re: 6.8 MPG ok?
#23 | |
Re: 6.8 MPG ok?
Also you have to take into account our trucks were designed back in a time when fuel economy was not a factor in America. Honestly American vehicles of that era worked on blunt force. Meaning raw power gets it moving and keeps it moving. they did not have the same finesse like their foreign counterparts. Yes ... that power is addicting hehehe
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. Last edited by Titomars; 04-25-2015 at 08:02 PM. |
#24 | |
Re: 6.8 MPG ok?
would be fun. |
#25 |
Re: 6.8 MPG ok?
The size of the Qjet doesn't matter for cruising, they all have the same tiny primary bores. The secondaries are vaccum controlled and adjustable, hence not a problem. If it was a problem GM would not have produced tens of thousands of the combo. If we were talking edelbrocks or holleys then its slightly different, but Qjets work fine on small engines which a 350 is not.
