Old 04-22-2015, 10:10 AM   #1
Edahall
Column repair, won't start, lock doesn't work
I repaired the floppy tilt and got everything back together but it now won't start. Also, the lock bolt doesn't pop out into the lock plate. I suspect that I didn't install the spring correctly.
Edahall is offline   Reply With Quote
Old 04-22-2015, 10:31 AM   #2
1774btcrew
1774btcrew's Avatar
Re: Column repair, won't start, lock doesn't work
You will need to pull the ignition lock cylinder back out. The metal spring on the left the goes in the gear for the rack goes in the slotted part of the black gear. A good way to make sure everything is working correctly is to remove the actual ignition switch at the bottom of the column. Move the rod up and down and watch if the pieces on the rack are turning as they should. If not, you are going to have to tear it back down and make sure everything lines up. Basically make sure from the bottom of the column by moving the rod it is making the pin for the lock plate move in and out.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 04-22-2015, 11:10 AM   #3
1774btcrew
1774btcrew's Avatar
I also should mention that if you have cruise control you want to have your turn signal arm installed on your upper collar and ran down your column in the proper place before you put the upper collar back on as it can be almost impossible to get down the column in the right location with everything together
Old 04-22-2015, 01:22 PM   #4
Edahall
My lock cylinder is not rotating far enough. This is as far as it will rotate. It won't rotate to the end stops. This is why it won't start. What do I need to do?
Old 04-22-2015, 01:34 PM   #5
1774btcrew
1774btcrew's Avatar
The metal spring still needs to be in the right place in the gear for everything to work correctly once it is all the way together. As far as your lock cylinder goes, I generally just replace them when they have that issue. Saves a lot of headaches in the long run
