Old 04-22-2015, 03:04 PM   #1
jadedbird
jadedbird's Avatar
lmc under bed tank work with fuel injection
Does the lmc truck tank work with lsx vehicles?
Do I need a different sender? I plan on -6an 3/8 lines and a 255 walbro inline pump and the corvette wix fuel fiiter and regulator set up
jadedbird is offline   Reply With Quote
Old 04-25-2015, 06:02 PM   #2
jadedbird
jadedbird's Avatar
Re: lmc under bed tank work with fuel injection
anyone?
Old 04-25-2015, 07:42 PM   #3
Indian113
Indian113's Avatar
I have a fuel cell and using basically the same setup you are wanting to use and have for 11,000 miles. I think the inline pump is a little noisy compared to the tank pump but I can live with it.
Indian113 is offline   Reply With Quote
Old 04-25-2015, 07:44 PM   #4
jadedbird
jadedbird's Avatar
Well I plan on running straight pipes dumped before the rear wheels on a 5.3 or 6.0 so I don't think noise will be an issue. Is the 60-66 sender sufficient to handle the ls?
Old 04-25-2015, 09:26 PM   #5
Indian113
Indian113's Avatar
your sending unit doesn't effect the LS Engine. It is controlled by electricity , Ohm's to be exact
Old 04-25-2015, 09:29 PM   #6
jadedbird
jadedbird's Avatar
alrighty. as long as its sufficent. im currently searching for a 99-02 harness to run with a 2000 5.3 i bought. theres a guy on ls1tech that will re wire the harness for a pretty penny. im hoping to have this up and running by end of july. but itll be torn down again next summer for paint and body
Old 04-26-2015, 09:08 AM   #7
awhite4557
awhite4557's Avatar
I initially used an in-line walbro 220 ml pump and had several issues. I ended up using a fuel cell and purchasd an in-tank pump assembly from tanks inc. It came with the same walbro pump that is submerged and works like a charm. The pump works better when it is submerged in the tank. The tank you purchased should work with this assembly with no problem. I ordered the PA 4 model. http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 05-07-2015, 02:32 AM   #8
SierraMtns
SierraMtns's Avatar
Yes.
http://www.powerblocktv.com/episode/...p#.VUsG3GavPis
SierraMtns is offline   Reply With Quote
Old 06-17-2015, 06:48 PM   #9
lutronjim
I used 65 GTO tank with fillup through back bumper.
http://www.tanksinc.com/index.cfm/pa...rod/prd378.htm
Be sure what ever tank you use, that it has baffles to keep pump from running dry on hard cornering.
lutronjim is offline   Reply With Quote
Old 06-17-2015, 08:27 PM   #10
TypeSL2
I used the LMC under bed, side fill tank. Cut a hole in the top, installed 2003 Silverado fuel pump, and made a ring to bolt on around the pump. No need for baffles since it is a pump used in a tank with no baffles and it is quiet and should be reliable. I have only had it running for a couple months, but I have had 0 issues with that so far.
James
TypeSL2 is offline   Reply With Quote
Old 09-29-2015, 02:57 PM   #11
geekitupsum
James
wanna come do the same to mine? lol I'm just down in spring hill
geekitupsum is offline   Reply With Quote
Old 09-29-2015, 03:56 PM   #12
pbr
I'm working on this now i'm trying the same route as typesl2 there is a company that sells the correct sending unit for most pumps with a 0-90 ohm signal. So i'm planning on using the sending unit from the newer pump with the stock gauge. Herko is the name of the company if you are interested they cost around $25.
pbr is offline   Reply With Quote
