Diff cover clearance with pan hard bar?
Im looking at diff covers and with the pan hard bar Im using I only have about 3-1/2" of clearance from the diff housing (where the bolts are). On summit they have a finned one that states its 5" tall... its a finned aluminum one. So I guess this puts me at somewhat of a restriction on what I can use. Anyone using a "No Limit" Panhard relocation setup and if so what diff cover are you using? What is your clearance from Housings face to the bar?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
![]() Join Date: Sep 2007
Re: Diff cover clearance with pan hard bar?
you would have to use the super track bar that has a bend to acommodate the finned diff covers. avail thru cpp ive seen
1967custom |
#3 | |
![]() Join Date: Jul 2009
I have a finned aluminum diff cover and you'll have to use either the CPP or PB "bent" panhard bar. I have both
I plan on getting a finned thicker cover as well. Discovered I had to get a bent bar once I dropped to 6". Here are some pics of the straight bar vs CPP bar.
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
yup thats the one i was thinking of
1967custom |
I completely understand your frustration, but you couldn't really expect a fabrication company to develop products with a bunch of other aftermarket companies parts in mind. There's just way too many variables in fabrication to accurately bring a product to market while still considering the vast amount of modifications that are done on these vehicles. If I were you, I would contact them and explain your issue. Many of us have had great luck with some of these companies standing behind their products and offering refunds or alternate parts to aid in the build process. I know ECE goes out of their way to help people.
Old member
Did you tell them what you where planning to run when you ordered it?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#9 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Well no, since this is the first c10 Im doing I had no idea it would even come into play, but Im sure they have run across this with many other builds.... I know better now, but now is already several hundred bucks out for the relocation setup.... A simple "this kit leaves 3-1/2" for diff cover" on the description would not have cost them near as much as the headaches of guys calling wanting to send the parts back.... right?
