HELP drop kit problems
My drop kit I ordered came in and am installing it currently, its a 5" 3" kit. Front went together well but im not seeing how the rear is suppose to work. The brackets don't make contact with under side of perch and im afraid it will not be centered or will walk. Help please and thanks
Re: HELP drop kit problems
I'm sure someone will chime but in the meantime do you have any pics?
Diggin The SquareLife
pics will help a lot....
![]() Join Date: Mar 2015
its a crown kit off ebay. I really don't like how cheesythis bracket is but will due for now, im just wanting to know how its suppose to attach and align I guess
order new u bolts.... won't fix that issue but it will make life easier when you redo this.
#8 | |
is this on a c10? it looks like you have a c10 kit on a c30 (axle tubes are bigger) |
#9 | |
The brackets should make positive contact under the leaf mounting pad. You should also use new u-bolts whenever doing a flip kit. Try using Bell Tech or Western Chassis parts.
Dang it... wish someone would have seen my post when I ask if this kit was ok lol. Trying to find kit I can have overnighted now
Summit Racing or Jegs are in your back yard almost.....
no one showing it in stock for 5"
#13 |
What do they show?
You installed a cheap flip kit. You just need a better quality flip kit for your model truck..... don't go by 5" drop.
#14 |
Reason I was doing 5 is because I don't want to do a C notch on this truck. Can I get away with that doing a 6 inch??
#15 |
they show a 6" kit but will I have to c notch???
#16 |
There is no such thing as a 5" or 6" specific rear drop when using a mass marketed flip kit. The 5" or 6" number comes from the number of leafs in the spring pack. A flip kit is a flip kit (it flips the rear from under the leaf packs to above them). The diff between a 5 or 6" rear drop is how many leafs your truck has. Fewer leafs = less drop. More leafs = more drop.
#17 |
I'd just do shackles and hangers then gets you a 4 inch drop. It's what I just did on my c30. I also removed the overload spring since I'm adding air helpers anyway and got it down another inch and installed new leaf spring centering pin bolts and u bolts wile I was at it.
#18 |
Thanks so much for the help Scoti ill try to run up to Jegs after work or Saturday morning. Im new to these trucks ive always built trifives and pre 72 chevys
#19 |
Whatever drop you have now would be the same w/a better quality kit. I would not run any flip bracket that is not reinforced under the axle tube (& why I suggest Bell Tech or Western Chassis).
#20 |
Only way I can find it and have it fast is with buying it with the c notch, ill just use the c notch on a future project. I didn't look into the flip kit like I should have and those flip brackets look like flat stock I could have made in my vise.
#21 |
What year/model are we talking about?
#22 |
1984 c10
#23 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#24 |
This is the one I would buy.
(Western Chassis) http://www.summitracing.com/parts/ws...olet/model/c10 SCOTI is an EXCELLENT source of info.. I would listen to him.
#25 |
I ordered the kit from jegs (belltech) no one has the basic kit with out c notch in stock. I need to get it on the ground this weekend and jegs says it will be here tomorrow
